Relocate Shifter
I was playing with the thought about relocating my shifter.
Has anybody any experience of this. Ive found a picture here of a aftermarket shifter. Does anybody have a drawing for a shifter like this one..
Track day car: 911 3.2 915 Black 1984 Daily driver: 911 3.2 G50 Blue metallic 1987 Winter car: Volvo XC90 2003 |
coolcavaracing.com
That is the Hargett Precision Shifter (in your pic)
Hargett Precision Shifter!!!! Good for track use, not so good for road use.
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Irrationally exuberant
A friend of mine moved his shifter back some. He shortened the rod some to do it as I recall.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Jeff |
coolcavaracing.com
The shifter covers the handbrake making it a bit impractical for road use...
Semper drive!
I've got absolutely no experience with either but, with all the talk about how much the Wevo Solid Engine and Transmission Mounts hold the transmission in direct line with the shift plane (improving shifting), I'm surprised that a shifter with such an angled connection wouldn't cause more problems than it's worth.
(Just my own $.02, which is probably way over priced! :-) ) Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
The parking brake is problematic for street driving, IMHO. Maybe the manufacturer could incorporate a vertical lever to set and release the existing horizontal parking brake lever. Sherwood |
I've got the Hargett shifter in my car and the handbrake is no big deal. Works like it always did.
The shifter places it up and back, making shifts a snap and next to impossible to miss when on the track. |
Semper drive!
I understand about the mechanics of driveshafts and CV Joints, no problem. In the picture provided above, the link between the shifter and the transmission is easily at least 20 degrees off the fore-aft plane, if not more. No doubt much more excessive than the most worn out of mounts would cause. Following the believe that the straighter, the better, this particular case above would seem to be extremely difficult to shift. Just a guess, but I would bet that, for some reason, it's not....but why? ![]() Randy
Actually it is the heater controls that are blocked, handbrake can still work. I did some mods to my Hargett to allow better access to the heater. I have a hydraulic parking brake so the e-brake thing was of no concern to me. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I've never driven a race car with a Hewland or other rear-mount gearbox, but the linkage path from driver cabin to the extreme rear of the vehicle is more tortuous than this and I hadn't heard Dan Gurney or even Sylvester Stallone complain nor do I imagine he (Gurney) missed many shifts. It looks like a fine product, and I have no doubt the parking brake handle is accessible. However, I'm still skeptical of the speed or ease of accessing it in an emergency situation. Sherwood |
Semper drive!
BTW, I'm not picking on Wevo, or even the Hewland shifter (which I really do like the looks of). I'm just stating my observation of what I've read here on this board. In fact, I've got a touch of bursitis in my right shoulder, and some days I'll put between 75 and 100 miles on my car...most of it city/burb driving. The angle of the stock shifter takes its toll on my shoulder in a big way. I would think the elevated shifter would be more comfortable, and a much better angle for the human body to be shifting at, much like the newer Carreras. Randy
The replacement products that replace the factory shift coupler use a U-joint. Here's a comparison photo of the factory shift coupler (left) and a custom shift coupler (right) nicely fabricated by Pelican PBH (same construction as used in aftermarket products) using a Torgeson-type U-joint (center): ![]() Sherwood |
The hargett shifter is in a much better postion then the newer carreras. IMO it is pretty near perfect. The product is not for everyone, but it works well and is nicely designed. I am happy with mine for my application.
Cheers
Not an expert on this, but I think it's the vertical plane that is important. The Hargett moves the linkage in a horizontal plane. Or maybe I'm completly mad.
I have solid engine and transmission mounts, but would never do this on a street or stock race class car. The sport mounts work well for these applications. In my case they did help the shifting when the car was under torsional load. I will eventually put a Hargett shifter in my race car primarily for the purposes of getting the shifter raised and moved back. I've heard it also shortens the throws and make it a bit notchy, but the improved hand position overcomes that. I don't recall who posted it, but someone on here raved about this product.
John Snodgrass 1973 Porsche 911 "Barney" (race car for sale) 2008 Nissan Maxima - Daily Driver 1999 F350 Diesel Crew Cab - Tow Beast 1990 Airstream 36' Land Yacht - Home Away From Home |
The Hargett is probably the closest thing to an upside down 935 style shifter. FWIW the angularity on the 935 was minimized by flipping the trans upside down versus a stock mount. I have not shifted a Hargett setup but have shifted a fully equipped WEVO trans. To be honest a freshly built trans, pretty solid (new polybronze) mounts and SC RS short shift kit was just as positive as a wevo.
There are a couple homegrown short shift/up and back linkage/shift setups out there. The one that comes to mind is the Gunnar Racing RATT setup and a picture that is floating around on Pelican of a 935 "style" shifter. Pretty cool if you ask me, they place the shifter up near the ashtray and leave much more access to the center controls. To each their own though.
74 911s neverending story. two feet and a jetta for now. |
Remember
I used the Hargett shifter for the G50 conversion in my 75, I relocated the parking brake and heater controls where the stock shifter use to mount, you gotta lean forward a little to use it but it works great.
My car is a street only hotrod, I love the improved shifter position (up & back) and the way it shifts.
Gary 1975 911S G50 3.5 Twin Turbo |
Semper drive!
Thanks for the lesson, Sherwood. Looking at it that way, using an actual u-joint, it really makes a lot of sense.
I'm about due to replace all my bushings anyway, I would imagine using the PBH version coupler would be, in the long run, a much better idea than re-using the stock, with new bushings. I've got sport mounts all around on my car now, new bushings and the PBH coupler should do wonders! ![]() Randy
