Mechanical vs. Electrical Speedometer/Tranny
I have seen a lot of Wanted-to-Buy and Wanted-to-Sell mechanical and electronic speedometers from our sponsor's ad. I know my 83 SC has electronic speedometer. But... my Forrest Gump q's are:
Are mechanical speedo's driven by cables attached to ...where? Attached to the tranny?
Are there mechanical tranny vs. electronic tranny? I have checked the extra mag tranny I have and the only electrical part I could see is the one for the reverse light? Are all 915's electronic?
Help!
Old 10-18-2003, 10:24 PM
Administrator
Jack Olsen's Avatar
Early trannies used mechanical speedos. I think it was 1974 and earlier, or thereabouts. You can adapt a mechanical to be electronic, but I don't know if the reverse is possible.
Old 10-18-2003, 11:14 PM
CamB's Avatar
It is '75 and earlier for mechanical speedo (and un-galvanised bodies and chrome mirrors). From '76 the speedo went electronic, they galvanised the whole body and the flag mirror appeared.
I would think it would be better to get the mag transmission converted, because running the mechanical transmission would be very difficult. Having said that, you would then need to get ANOTHER SC speedo and get it recalibrated for a 7:31 R&P (assuming that is what the mag tranny has). 7:31 last year was apparently 1974. The 1975 has the first 8:31.
In fact, as years go, '75 kinda sucks (see below, I oughta know). They rust, they don't have short gears. They don't have a decent exhaust (the '74 did).
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 10-19-2003, 01:39 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Windsor,
The mechanic 915 speedo drive is at the nose of the tranny right next to the gear selector shaft. It's a threaded piece with a little flat shaft inside. The mechanic speedo cable screws to this thread. The electric pickup on later 915 trannys is at the cover plate for the differential. It's a hall sensor that "listens" to a sectored disk inside the diff housing. I converted my 915 to electronic by using a VDO-supplied transducer. It screws onto the nose of the transmission where the mechanic cable used to go. My 993 speedo is about 1% off the mark (checked with mobile GPS)
Ingo (from Japan)
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 10-19-2003, 07:01 PM
IROC's Avatar
Actually, the electronic speedos began sometime *during* the '76 model year. I have a '76 and it has a mechanical speedo. My car was mfg. in Dec of 1975.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 10-20-2003, 04:59 AM
hifeverz's Avatar
Ingo:
Where can I get one of these and will it fit on my '74 transaxle? . . . approx. $$ and would you know of a supplier or website??
thanks,
Hz
1979 911SC Targa
1979 930 Turbo Coupe
1974 911 Targa
Old 12-01-2007, 04:25 PM
ischmitz's Avatar
I bought mine in Germany at a shop that is a licensed dealer for Kienzle and VDO. They retrofit logging devices into commercial trucks and stuff.
Unfortunately, I have never been able to locate something similar here in the U.S. All the pulse sender that I found here (used for aftermarket GPS applications) were 6 pulses per rev and you need eight. Maybe a speedo shop such as North Hollywood Speedo can help.
Sorry for not being of more help.
Ingo
Old 12-01-2007, 05:33 PM
