89-94 H5s in an SC
Will 89-94 H5 headlights fit into my SC buckets? If there are plug adaptations, will they fit cosmetically until that can be done?
Rob L.
Currently have too many cars
to properly care for
Old 08-20-2007, 07:02 AM
Diss Member
Quicksilver's Avatar
I think the real question is why would you want to put on a replacement with a substandard beam pattern and less light output?
Put the Euro H4s on it. That is by far the best lighting upgrade you can do on the car.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 08-20-2007, 07:32 AM
Zeke's Avatar
From what I can tell on mine, they are a direct bolt in/plug in. I'm getting used to the H5's and starting to like them.
Whoops, I just read that the plug is different. The buckets should be the same. I have not seen any significant differences, but I have seen everything, yet.
Old 08-20-2007, 08:02 AM
h5 headlights in an SC
Well, at this point it would be just as an aesthetic fix...get rid of the sugar scoops...I have been told that the 89-94 wont fit as the fender is diff....I do not buy this...can anyone tell me if they will or won't? I only drive the girl during the daytime and on weekends, so quality at this point is less imp as looks (soun ds like my first marriage)
Rob L.
Old 08-20-2007, 08:07 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I don't think they'll be a straight bolt in since the H5 aiming bucket/cage uses four threaded tabs that are inside the fender bucket to mount the H5 assembly? I don't have a picture handy to show this and a search in the archives didn't result in anything for me.
Kevin L
'86 Carrera "Larry"
Old 08-20-2007, 09:48 AM
I took the H-5's out of my '77 to fit H-4's. The bulb connector plug is different, but the buckets are a straight swap.
H-5's are a huge improvement over sealed beams, but the H-4's are better.
'77 S with '78 930 power and a few other things.
Old 08-20-2007, 12:54 PM
Me like track days
Craig 930 RS's Avatar
H4s are easy to install - don't do what I did in 1999 and go for the sexy smooth US federalized H5s - they sucked big time compared to the H4s I installed later when I was........smarter.
No wonder the guy was so happy I bought them........
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 08-20-2007, 01:01 PM
H5s are US only junk. Buy H4s with and a set of paintable rings. You'll get the look you are after, and really good head lights. They plug right in, and are held on by one screw.
Old 08-20-2007, 03:49 PM
