Help with '67 flasher unit!?
I've got a '67 912 and the turn signals won't blink. I replaced the flasher unit, which was an elusive 5 pronged experience (with spade fittings, not a plug-in unit).
It has two independent terminals at one end, a common-two pronged terminal in the middle, and a single terminal at the other end. The wiring diagrams I have looked at show only three wires (of completely different colors than what's in my car) going into a unit and the terminals have different numbers on the diagram. Anyone have this experience and know what I should plug in where? I have a red wire carrying 12volts with a siamesed red coming off of it, and a brown ground wire as well as two others of varying stripes. ANY AND ALL ADVICE WELCOME! Cheers, Nick |
Nick,
Been there, done that, reverse-engineered it! See here and post your questions on the below thread. http://forums.pelicanparts.com/porsche-911-technical-forum/68155-need-advice-blinker-hazard-control-unit-early-901-a.html?highlight=stribel |
| All times are GMT -8. The time now is 05:23 AM. |
