Downtownandy's Avatar
Heater smoking inside cabin
Sorry if this is already covered in another thread. Pulled over on the side of the road right now on my way to Texas from north Carolina because I started smelling something burning and then smoke started coming in the cabin from the heaters under the dash. I shut it off and pulled over immediately. Started the car up and drove to the next exit to get off the interstate and there is no smoke with the heater off. One additional detail is that my crank pulley seal is still leaking a bit of oil which the pulley then flings around the engine compartment, including the cooling fan where the heater sucks air in from. Maybe that got gunked up in my heater and started burning? Thoughts? It might be a cold rest of the 18 hrs..
Old 12-15-2012, 12:18 AM
pete3799's Avatar
Likely a shorted blower motor.
What year car? Footwell blowers?
Unplug the blower (s) and you still should have some heat.
Pete
79 911SC RoW
Old 12-15-2012, 05:29 AM
85, footwell blowers yes. And thanks!
Old 12-15-2012, 06:09 AM
+1
I have no motor blower or footwell blowers. With stock H/E's, would still have to turn the heat down/open the windows in traffic. That stuff is just for around town - shouldn't need it on the freeway - the big fan on the motor pushes a lot of air at anything over idle.
What does the smoke smell like? Oil? Electrical? Exhaust? If it's the latter, keep the windows open, either of the first two, just disable the blowers....
'77 S with '78 930 power and a few other things.
Old 12-15-2012, 09:38 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Oh damn Andy,
+1 Remove the foot kick panels and unplug the foot blowers.
'85 Carrera Targa
PCA/POC
Old 12-15-2012, 09:46 AM
DRACO A5OG's Avatar
He is off on the road and disconnected the foot blowers, all is good plus heat not smoke.
So Andy that may mean your foot blower motors may have fried. Sorry :-(
'85 Carrera Targa
PCA/POC
Old 12-15-2012, 09:57 AM
cjannelli's Avatar
I have a foul odor that I think is coming from the blower motor in the engine compartment. How do you disconnect that motor?
Chris
Old 12-15-2012, 10:20 AM
DRACO A5OG's Avatar
Remove fuse inthe engine bay or connector on top of the motor
'85 Carrera Targa
PCA/POC
Old 12-15-2012, 10:38 AM
cjannelli's Avatar
Thanks!
Chris
Old 12-15-2012, 10:55 AM
It smelled electrical. My footwell blowers are good. The one in the engine bay is the one that fried.
Old 12-15-2012, 06:29 PM
DRACO A5OG's Avatar
Oh damn, that's too bad, well, you can go the cheap route and put a real cheap "Grainger" motor will work but maybe not all the levels on the foot blowers or buy a replacement from our host.
I did both routes and found in the end needed all levels to work properly
'85 Carrera Targa
PCA/POC
Old 12-15-2012, 10:48 PM
