AT wits end- 85 3.2 rough idle
OK gang- I have spent about 2 hours reading all the posts related to rough idle- I'm stuck.
Please read carefully- I have done a bunch of legwork and testing already. I'm not looking for ready-fire-aim help here. I think I have exhausted the most common issues. I can safely assume based on my testing that it is not a vacuum leak, fuel filter, cap, rotor, plugs, injectors, O2 sensor or the like. It has to be deeper than that. Here's what I have done so far: Top end rebuild, new rings, new exhaust valves, cat bypass 300 miles ago. Uses no oil at this point, and I would consider the rings seated and overall engine condition is excellent. Leakdown 2-3% across all cylinders Replaced all intake gaskets and spacers due to a "mistake" at initial reassembly, no leaks at intake. Injectors have been tested and cleaned on an ASNU machine. Two are new Bosch due to leaks. New O2 sensor Cap, rotor, plugs new since rebuild. Rubber 90's on the fuel pressure regulator and fuel pressure stabilizer are new as well as the "Y" connector on the manifold. All diaphragm items like the regulator, stabilizer, and brake booster have been tested for leaks- all OK. Other lines to oil tank, thermal switch, etc have all been verified as good. Fuel quality switch on DMEis at pos. 0 Ground connections on manifold are tight. No corrosion on multi-pin connectors in engine compartment. Idle swicth is actuating and pin 2-pin 5 shows .09 ohm resistance (is this acceptable?) Plug wires are Clewett's from our host and tes OK. CHT resistance is OK, and is 3 wire type 2 years old. ICV operates- you can feel it vibrate with key on, I cleaned with carb cleaner and tested on bench, does actuate both ways when power applied to the appropriate pins. Here's the symptoms: Runs great above idle. Good power and performance driving. No steady throttle stumble or hesitation. Cold starts are great. Idles at 1000 RPM for about 90 seconds, then idle drops and becomes lazy. I wouldn't say there is a miss- its just rough. The idle (according to the dash tach) goes to 600-700 as soon as the O2 comes on line. Disconnecting O2 causes smoother operation. Disabling the ICV brings idle up a little. If I adjust the base mixture at the AFM, i see very little change in adle quality. Changing the idle speed via 7mm adjuster brings idle up a little, but as soon as you connect ICV and O2 it goes right back to the rough symptom. It almost seems as though if I could get the idle up to 800-900 RPM, the roughness would be gone. The problem is the system takes over and drops it right back down to where I started. Thanks for your help!!!! Dave |
"It almost seems as though if I could get the idle up to 800-900 RPM, the roughness would be gone."
How about raising the base idle speed? Joe |
Joe- did that, as soon as I hook the O2 back up, and enable the ICV, the idle returns to its prior speed and quality.
Dave |
Have you checked for an air leak at the oil filler cap?
Thanks Mark- I will check that- the cap is new, though and I can hear a change in idle when I emove it.
I am thinking that I have something else going on- maybe an AFM problem or DME issue. rather than an engine sealing issue. |
I feel your pain and just a quick thought...
Do you have a performance chip in the DME? If so, did you unhook the brown DME wire (under driver's seat)? This seemed to smooth out a number of rough idles including mine. Look at 911 Chips website and you will see Steve Wong's info on that brown wire.
Good luck and at the very least here is a free bump! Darrell |
Darrell- no performance chip, brown wire is disconnected. I did connect it to see if it made a difference- no change.
Thanks for the bump. |
intake leak? spray some brake cleaner to see if you have any idle fluctuation.
Check your brown wire at the DME box. Clean your ground strap at the transmision. How many miles on your injectors? Have you checked your voltage? |
Do you have the reducer cone in the breather line to the oil tank? That reduces the potential impact of a vacuum leak at the cap.
How about your idle switch - what is the resistance when the throttle is open? |
Did you opt. for a lighter flywheel with the engine rebuild??
Jeremy- thanks for the input, but please read the posts and responses.
All vacuum leak possibilities have been investigated and all rubber parts replaced. I am not new to this issue on the 3.2. The only one I haven't checked is a leak at my new oil cap. Brown wire- see post by Nashville 84 and my response. Ground strap- good call, but was cleaned prior to my reinstall of the engine after the top end rebuild. Injectors: as posted in my original background/question, injectors were cleaned and tested on an ASNU machine. 4 tested fine after cleaning, remaining 2 were replaced with new Bosch 158's. Voltage is a steady 13.5 with engine running regardless of load. VR has less than 1000 miles on it. This issue has been in the backof my mind for a while- what may have been damaged in the failure of the VR? Mine was catastrophic-it took out the clock, alarm module, tach, speedo, turn signal relay and DME relay. All of these items have been replaced since then. For a time reference, everything replaced on the car since I have owned it was after the VR failure- it happened on my drive home after purchase. Could this have damaged the DME, and how would I tell? DW Reducer cone is in place. Idle switch is completely open when off idle. I am still wondering if my resistance reading at the DME for the closed switch is too dirty for the DME to read a path to ground. Nine9 No WUR- 3.2 Carrera 911 Quest No- stock flywheel- I would have expected a lopey idle if I had changed the flywheel or cams. Engine is stock. KC The ICV is original as far as I know. I was trying to avoid throwing $175 at this just to find out if it is good or not. I do not have a known good unit to test with. I have tried the "bench test" procedures from other posts, and electrically the unit operates, and it will slam open and shut mechanically. Any thoughts on a good functional test procedure? I can drive an NPN PWM signal, but I am guessing that this is PNP. Keep 'em coming, there are a couple of possibilities listed that I need to check, but I am beginning to think I need professional help... |
Its a longshot, but have you verified the ICV can rotate through its full movement? The reason I ask is that I had a idle hunting issue, couldn't find the problem until I actually opened up the ICV by bending back those little tabs and removing the whole outer casing. What I found is one of the magnets had cracked, preventing full movement. Once I cemeted the magnet back together and re-installed, problem was cured.
Jon |
I know someone else has mentioned the AFM - have you had it apart to reposition the wiper arm over fresh substrate material?
Like KC911 suggests, if you come up to a stop sign and push the clutch in, do your rpms drop below idle and almost make the car stall? If so, then replace ICV. I would replace it anyway if it's original. I haven't owned one that lasted more than 6 yrs without issue, and the tests are sometimes inconclusive. You seem to be chasing a very minor issue. You could also wait until it gets worse for easier diagnostics.
David |
I know you've tested the injectors and so forth, but I have to say I'm a bit skeptical of the 2 newies and the 4 oldies combination. I know these injectors are $$$$ but...
I had the six original 158's in my car. I pulled them and took them to be tested and they were pronounced fine. I replaced with six new 159's and the car exhibited better running characteristics; some have reported a better idle. Just throwing it into the mix... ianc |
84-86s don't as well as the 87s up because of the programming. Try sticking a DME or chip from a later car and you'll see what happens.
Otherwise, make sure you really have no intake leaks. Use engine starting fluid and spray all around the intake with the O2 and ICV disconnected. If the idle shoots up you have a leak. Second, adjust the idle CO to 0.6 to 0.8%. Finally adjust the base idle speed by jumping the B-C test terminal on the left side of the engine compartment and setting to about 800 rpm. |
If you are adjusting things without an idea of what your AFR is you are basically doing it blind... I myself had the same problems which went away after my base mixture was adjusted with the proper tools. It would help to have the proper tools to get the job done right, or hire out to a mechanic. Since it looks like you've done everything else, my guess would be that it is your base mixture that is off. Like steve said, make sure your base mixture is set correctly, then set idle by jumpring the terminals and adjusting the idle screw. I think those 2 things done correctly and in that order should solve the problem if you don't have any vacuum leaks or electronics issues. But you can't do it without having a gas analyzer or an equivalent analyzing tool - won't work if you are trying to adjust the base mixture blind. |
[QUOTE=mackskibum;3448031]KC[/B]
The ICV is original as far as I know. I was trying to avoid throwing $175 at this just to find out if it is good or not. I do not have a known good unit to test with. I have tried the "bench test" procedures from other posts, and electrically the unit operates, and it will slam open and shut mechanically. Any thoughts on a good functional test procedure? I can drive an NPN PWM signal, but I am guessing that this is PNP. Is there a Pelican in your area with a 3.2? It's so easy to swap out (and check), that I'd ask. I did all the "bench testing" too on my original ICV, and although it "tested OK", a new one was indeed the "fix". If your's is original, it's just a matter of time anyways imo. |
[QUOTE=KC911;3449206]
There is no need to waste $175 guessing if the ICV is bad. If you do the proper tests, you should be able to determine if the ICV is good. The procedures are in the factory manual. Part of the test from the manual is to test the ICV is to start the engine with the a/c and lights on and terminals b&c jumpered. The idle at start up should be low b/c the a/c is on. Pull the jupmpers out and the icv should compensate and idle should rise. Turn off the car again, and pull the vacuum hose on the FPR off. Jumper b&c and turn the car on. The idle should be high. When you pull the jumper, the ICV should compensate. Also the there are electrical tests for the ICV in the manual. Check the ohm specifications. As well as applying 12V (per factory manual) to the outside prongs alternatively, (and grounding the center). Arm inside ICV should rotate to each side alternatively as you move 12V to the other outside contact. |
I had a similar idling issue once. When cold it would idle ok and then get lazy, bouncy and eventually die. It was a A/F mixture issue. It turned out to be the connector that goes to the AF meter. Two of the contact on mine pushed back and were not making good, if any contact. Simple check, you can pull the boot back and check the 4 wires and make sure the contacts are fully seated in the connector.
The way it was explained to me by my wrench - basically as soon as the idle microswitch is engaged - then the ICV takes over responsibility for the idle function and fluctuation.
If you don't have any leaks in the intake (and believe me - I did the same thing you did - rebuild my engine - new rubber, etc - i still sprayed a little brake cleaner to cross that off the troubleshooting list. Make sure your vacuum hoses are secure as well - I had one that was about to come off - thought I found the problem, but turned out it had little to do with the idle. Then the next step is replace the ICV. Hell you probably spent more than $175 in time already. I replaced mine - and it did smooth out my idle, even when I tested it, cleaned it and assumed it was running fine. |
Well, after a week to think about this and travel for a while, I am back at this problem. Thanks to all who posted during the last week or so. So to respond to the folks that posted in my absence:
Javers While I have no way to determine if the ICV is functioning properly, I have to believe that it is making it all the way to the stops when power is applied to both sides- when on the bench it will clunk against the stop on each side when polarity is reversed. Mark The AFM is a reman- less than 2500 miles on it. That doesn't mean that its good. To verify, I swapped it with the old one and no difference. I don't think its an AFM problem at this point- although it may be an internal adjustment problem- more on that later. rallyracer Not my symptom- twice 2 years ago I got the bouncing idle thing, but it went away. No problem this way since. ian At my top end rebuild I replaced all the injectors with remans from a mass rebuilder. I was facing a budgetary crisis at the time, and in hindsight I should have dropped the $800 and went with all new. The ones in the car now are newly cleaned and tested by a local shop that I used to work for. I actually used to run the machine they use, so I am pretty familiar with the process. I have a high degree of confidence that the 4 they called good are actually OK. The 2 replaced with new were due to 1 body leak and one that wouldn't hold pressure without leaking at the pintle. Since the car performed the same with both sets, I am looking elsewhere. Steve W I have exhausted the vacuum leak thing unless it is somewhere I can't find external- lets say the ICV won't close for example. The idle is so bad that it has to be an issue- idles like there's a cam in it. No Porsche buyer in '85 would have accepted this. As far as mixture was concerned, I was trying to "wing it". No success. In the interim, I purchased an LM-1, and did some testing today. I can not get below .81-.82 with the reman AFM installed. This is with the bypass screw dialed all the way in. I need another couple of turns to get this to the .6-.8 you mentioned. Car definitely runs better here that anywhere else I tried. A couple of procedure questions: Do you set mixture with the ICV not bypassed? I did it with the pins jumped, O2 disconnected. Could a bad ICV give me unmetered air into the circuit? This could explain my being out of threads on the bypass screw in the AFM. FWIW, I tried the same procedure with my "old" AFM- results were actually worse- I couldn't get lower than .85. Could this be an internal AFM adjustment? Reindex of the door position to resistance? 84porsche9113.2 Yep, was trying blind- see above. KC I may land here, but I'm not ready to make that commitment yet. I would rather complete the troubleshooting process first before condemning parts. 84porsche9113.2 I have done the bench test procedure you describe, and the ICV moves bothe directions. My AC is not installed yet due to the top end rebuild. I have been chasing these issues, and its sure easier to work on it with the compressor and lines out of the way. I am stuck on that part of the procedure. don911 Connector is OK- pins are in good shape. Jeremy I may still have that problem, but it doesn't explain my adjustment issue above. Thanks for all the help, I think I may be making progress finally. Please keep em coming!! Dave |
In another thread, Steve W. Gave me some specs- I need to reset my mixture- I confused Lambda reading with CO%. I'll be back at this tomorrow night.
Dave |
The LM-1 does not measure CO. It displays either air fuel ratio or Lambda, which is the ratio of the current AFR/14.72. You do not want idle Lambda at 0.6-0.8, which would basically be belching fuel out the tailpipe as that would basically be an AFR of 6:1. Idle lambda should be around 1.0, or 14.2-14.7.
Steve, thanks again for answering. I got the info from my other post that you answered. I will be at the adjustment again tomorrow- mixture and base idle speed. I will post results- hopefully solves my issue.
Thanks Dave |
Did you check that the distributor's advance mechanism is working correctly? These can get gummed up and not retard the spark very well when the engine drops to idle.
Bob |
OK- here's the latest. I reset the mixture per Steve W's suggestions. O2 disconnected I am now at 14.1-14.3 AFR at idle. O2 reconnected, I am at 15.7 to 17.2 AFR- lean, rough idle. The interesting thing is that off idle, the mixture falls to 14.5-15.0- a little bouncing, but within that range. As soon as the engine drops back to idle, the mixture is back to the lean condition.
Any ideas?? Thanks Dave |
What are you using to hold the O2 sensor on the tailpipe? The Innovate exhaust clamp or something else? If a piece of pipe is used, the exhaust reversion will cause false readings at idle. Also exhaust leaks before the O2 sensor can leak air and affect the O2 sensor readings.
Steve, we may be on to something here- I have an exhaust leak at #5. I will look at this tomorrow. To get the reading, I was placing the LM1 o2 sensor in the tailpipe by hand and making sure that the cable was bent so it was in open air to the side. I agree that it is not scientific. I will likely order the clamp from Innovate to eliminate the fudge factor here.
FWIW, if you bypass the ICV with the jumper wire, the idle smoothes out some and the readings go back to 14.8-15.5 at idle. A question- would the exhaust leak cause problems during setup as well? I can get the mixture dialed in OK with the LM1 O2 in the bung for the factory O2, and the idle is pretty rough, but its much worse with the DME O2 connected and in place. Steve, again, thanks for your help. Dave |
That won't work at all - not even anywhere close. Either stick it in the factory O2 bung, or buy the Innovate exhaust clamp.
Steve, maybe you misunderstood me. I used the bung in the cat bypass to do the settings. I then replaced the OEM sensor in the bung and reconnected the wires to put the system in closed loop. The rough idle only happens when the O2 is connected to the DME. I have a high degree of confidence that the mixture is set correctly at this point, exhaust leak not withstanding. The sensor in the end of the tailpipe was a "sanity check" to see what happened at sensor reconnect. I will order the clamp from Innovate to make sure.
Thanks Dave |
Mackskibum,
So it's been over six months, have you found the culprit? I recently put back my Welmeister Chip, corrected the Fuel/AIr Mixtures using the Connect the Red Lead of my DVM to the O2 Sensor and Black Lead to my Intake Manifold Ground. DVM reads 0.3 - 0.5. Base Idle set at 880 RPMs ( 4K DME ) maintained 880 RPM's when jumper was removed. I thought it was fixed but when I took her out for a test drive, at stop the idle would settle to 880 RPM's then slowly trickles down to 780RPM's (rough idle). She will not stall and AC will not effect the idle ( like it used to when I had the fuel mixture too rich, sometime stalled with the AC on ) Like you I have no Intake Air Leaks. Replaced: DME Relay CHTS ICV O2 Sensor Cat By-Pass with O2 Bung Distributor, Cap, Rotor & Wires SW Chip on Standby until I fix this Idle Issue. Hope you had success, Jim |
Maybe re-check the distributor indexing.
What spark plugs are you running? I tried those fancy pants Bosch plugs once and it ran like crap.
Thanks 911st & CGarr
Yeap "Fancy Pants" Platnium 4's. PO put them in there but I did not know that until I serviced the plugs. They were in perfect condition and firing is not an issue. She does not misfire in anyway. It is the trickle down in idling that is an issue. |
I think it may be that I am running too lean my DVM auto reads at 2 Volts = d.ddd mV:
My readings show 0.020 - 0.034 mV at the O2 Sensor non BC Jumpered Idle at 810 RPMs. Will try to bring the mixture up to 0.200 mV+ The wierd thing is when running I assume lean the ICV definitely Kicks in to keep the idle maintained when I turn on the AC or HeadLights or both. When rich it would want to stall when I have both on. It doesn't even blip. |
Wow, it seems like this has been a hot topic for as while, and I walked away from my original problem over the winter. I am just getting back into this now to try and settle this issue. This has been one of the toughest troubleshooting processes I have ever undertaken.
Where I left it last fall was that I was attempting to tune using the LM1 without the venturi adapter. I have since pruchased the innovate exhaust clamp/venturi and have repeated the tests. I still have the lean idle issue no matter what I do with base idle settings and AFM idle misxture adjustment. Here's where I am at this point: Between last fall and now I have replaced another suspect injector from the set I had cleaned last year. The report showed a higher flow by about 7% over the same period of time at 4 bar pressure. I had a spare- the logic was that the flow migh cause an imbalance from 1-2-3 and 4-5-6 that could cause a lean on one side and a rich on the other thus creating a rough idle as the O2 tries to manage the situation. I found a small vacuum leak at the rubber boot that ties the two intake manifold halves together. This has been corrected, and I can find no other unmetered air leaks in the syste, using a spray liquid at the suspect areas. I repaired the exhaust leak at #5 I repaired an exhaust leak between the muffler and the Fabspeed bypass Replaced the ICV with a new unit Replaced timing chains and sprockets (unrelated, but had to go there due to an oil leak between the chain housing and cylinder head) As it stands now, using the LM-1, I get approx 14.2 AFR, 1.0 lambda anywhere off idle. At idle, with ICV bypassed and O2 disconnected, I can get close to those numbers by balancing the base idle adjustment and the AFM adjustment. In this format, AFR and Lambda are 12-13 and .8-.9 respectively- I am assuming this is the richer map in the DME for open loop sensor failure mode. Reconnecting the O2 by itself makes little change in idle speed or mixture. As soon as I take the test lead off and allow the ICV to come back in, the AFR goes to 15-18 erratic and the lambda numbers bounce between 15.5 and 17, and rough idle returns. I have verified that the idle switch is completing the circuit at the connector underhood. I have not verified at the DME end of the harness. Full throttle switch is open until full throttle is reached. I also tested the CHT resistance, and the cold value was 1.087Kohm at 50 degrees F. I did not have the opportunity to test resistance hot yet, but I have a hypothesis and question: If the sensor is supposed to be 2.2-2.8Kohm at room temperature, and somewhere around 350 ohm hot, and I am starting the process at 1.087K, it would seem to me that I am sending a request for lean mixture to the DME from the get-go. Then as it warms up, and resistance changes, I am still sending a lean request because the resistance curve is functioning at half of the specified resistance. Is this correct? - That is as temp increases and resistance decreases the fuel bias goes lean? I am hopefully finally on to something here- it would be nice to get this project behind me and actually be able to enjoy this thing when sitting in traffic or at a stoplight. FWIW, the CHT is relatively new- less that 2K miles, and I had discounted this as a problem. Apparently NEW stands for Never Ever Worked! Thanks for reading- I welcome anyone's opinion on the newest information I have posted. Dave |
O-ring on oil cap? Per a previous post, I replaced mine (quite hardened) and idle smoothed out noticeably.
| All times are GMT -8. The time now is 02:55 AM. |
