North Coast Cab's Avatar
Bump Steer Heim Source
I cracked one of my heim joints on my ERP bump steer kit. I beleive the turbo tie rod ends utilize a M14x-- thread. Anyone know where I can get a replacement heim instead of spending $300 on a whole new kit?
Thansk, John
1985.5 944 GTS
Old 08-27-2007, 04:16 PM
Give McMaster Carr a shot. www.mcmaster.com
Old 08-27-2007, 04:52 PM
Stophos's Avatar
Contact ERP directly first who may refer you to Smart racing Products. (There is a question in regards to the quality of other sources so you may not want to chance it.) If the problem occured for no good reason I think you will find that ERP will replace it gratis.
-Chris
Old 08-27-2007, 06:52 PM
+ Chris on this. Heim (or rose in Europe) joints come in many types, materials, and qualities. Be sure to use only the one specd by the kit manufacturer. Try to analyse why it failed; nine times out of ten an installation error is the culprit.
regards,
Phil
Old 08-27-2007, 07:30 PM
barney911rs's Avatar
Truechoice or Pegasus both sell high quality race parts, you might try them if ERP can't help you.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 08-27-2007, 09:58 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
aurora bearing co.
james lister & sons
open any race tech magazine, go the back and look under the suppliers section, there is a wealth of stuff there. almost all supply motorsport exclusively. there are cheaper options out there, just look.
74 911s neverending story. two feet and a jetta for now.
Old 08-27-2007, 10:12 PM
Can someone verify the thread size and pitch on the turbo tie rod end?
1985.5 944 GTS
Old 08-28-2007, 03:42 AM
Ok, so I didn;t have much luck sourcing a replacement from ERP as I beleive they are out of business. I was talked into the Rebel Racing full set-up and it came in today.
My concern is that the rod end is much shorter on this kit than the one from ERP. It will work, but will only bite 4-5 threads on each side. Is anyone racing with this set-up or does anyone know where I can buy a different rod end with a longer shank?
John
1985.5 944 GTS
Old 08-30-2007, 05:03 PM
John,
I have that bump steer kit, but my car is still sitting on jack stands. I screwed them on the same number of turns as the ends I removed, but I have no idea what my toe setting is. I need to have the car corner balanced and aligned before I do anything as I'm replacing the entire suspension.
John Snodgrass
Old 08-30-2007, 05:18 PM
ERP is NOT out of business but they work through their distributors.
My suggestion is to communicate with one for any spare parts or support.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-30-2007, 05:59 PM
Chuck Moreland's Avatar
The rule-of-thumb for thread engagement is that it should be at least the diameter of the thread, in this case 14mm. The tie rod has a 2mm thread pitch, 4-5 turns is only 8-10mm of engagement.
Off-the-shelf rod ends are too short. I had long rod ends cu$tom made to my specs for my bump steer kit. I'd offer you a rod end but I don't think it will interchange with the ERP kit. My understanding is the ERP kit uses an inch-measure bearing with 14mm thread.
Steve is an ERP distributor, call him.
Chuck Moreland - elephantracing.com - vonnen.com
Old 08-30-2007, 08:23 PM
Stophos's Avatar
ERP = Cary at carnutt@aol.com
Old 08-31-2007, 06:29 AM
