proporsche's Avatar
911 early WUR and cold start valve
Trying to help a friend.I do not deal with AFR system set ups.
He has an early 75 911 at the shop.It has very early WUR and cold start valve(no Bosch plug on cold start valve)
The engine is running very lean-if it it adjusted richer it kinda floods.
Control pres.i ok and system pres.also ok
the numbers are cold-10-12--warm idle 13..running 15-16..
There is a possibility the engine has 3.0 pistons and cylinders -there is no history with the car.
Any ideas.Like getting different WUR -perhaps
thanx
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-30-2025, 03:26 AM
What is the WUR part number? Is it the correct one for a ‘75?
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/
Old 07-30-2025, 03:43 AM
proporsche's Avatar
That is the good question..i just finished one engine 911 1975 and it has the same wur and cold start valve...it came to me in 1000 pieces-maybe it does not belong.I go look at mine and call my friend
thanx
Ivan
Old 07-30-2025, 04:11 AM
proporsche's Avatar
the number is 0438 140 129
Old 07-30-2025, 05:50 AM
proporsche's Avatar
more info-i think we going to get another WUR ,he has in this engine..possibly 2,4 or 2,7 with S cams early WUR.
Old 07-30-2025, 07:46 AM
E Sully's Avatar
I believe the WUR for models with the hand throttle lever by the parking brake and Throttle Position Regulator were originally 008. The 0438 140 129 was the factory replacement for it.
The late model '75-76 without the hand throttle and no TPR used 0438 140 009 vacuum controlled WUR.
Ed
1973.5 T
Old 07-30-2025, 01:11 PM
proporsche's Avatar
Hi Ed
yup i second this...we are going to get for my friend the later version.No vacuum - i think that was for emission purpose...this engine is kinda all Mickey Moused together,it runs strong(i think it has those S cams) but my friend cannot rich it up...so Wur is on its way-no hand throttle there..78 body..
Thanks a lot for your input...
Ivan
Old 07-30-2025, 02:18 PM
E Sully's Avatar
What is the engine type number to the right of the fan housing by the cylinder?
Ed
1973.5 T
Old 07-31-2025, 06:49 AM
proporsche's Avatar
Hi..Ed..i just came home from Prague ..went to look at the engine plus pick up my engine case for the new build i`m doing.
Looks like 1974 engine with 2,7 piston and cylinders with the very early WUR possibly from 1973.So there is not enough gas going in since the wur cannot be adjsuted. My friend had the engine running very good but only with his adjustable fuel gauges....bypassing the wur.
Engine is 911/92 so it is most likely late 1973 early 74 injection ..
Ivan
Old 07-31-2025, 08:39 AM
Those early wurs adjust very easily with the hex bit adjuster on the bottom, check it out.
Old 07-31-2025, 08:46 PM
proporsche's Avatar
Ok thanx i did not know ..i`ll tell my friend
Ivan
Old 08-01-2025, 12:30 AM
proporsche's Avatar
Eastbay...my friend said thank you very much and me too. We learn every day.....
The fuel press was very easy to adjust and the car runs perfect.Since you have saved him a big headache--he said if you ever come to Prague-Czech Republic-Bohemia he will invite you for a quality Czech beer ...
thanx again
Ivan
Old 08-01-2025, 05:56 AM
thanx again
Ivan
cool, the early stuff has its own charms.
yum, Czech beer is my favorite. I'll see if I can pencil in a trip.
Old 08-02-2025, 06:42 PM
