vracer's Avatar
My '89 alarm is set & turned off by the ignition/door key. Does that mean that if I locjk the door with the key, wait a while, and then try to start the car, it won't start?
Richard
1989 Venetian Blue Targa
Old 05-31-2011, 12:35 AM
pmillikin's Avatar
Cory -
As you probably saw in the post the fix worked perfectly first time on my '86. If you like I'll take a pic tonight in order to confirm the connections involved. Other than that I'm sure some EEs are out there to assist.
Cheers,
Pete
86 Carrera #178
Old 05-31-2011, 11:01 AM
Send a message via AIM to NoLift911
Does anyone know the years that the alarm codes/modules changed?
It seems that this method will work for SC's and Carrera's - but the module was different.
I would think the 84 would be different with the introduction of the DME.
I have mine rigged right now but would like to remove all together...
Jeff
Old 05-31-2011, 11:09 AM
Cory M's Avatar
Originally Posted by pmillikin View Post
Cory -
Cheers,
Pete
Thanks Pete. I followed the directions exactly and it turns over but no spark. There is a chance it is due to some other ignition problem or unhooked wire or sensor. The wiring harness has been altered a lot from stock so it isn't as easy to troubleshoot, and I hate electrical work! I messed around with it for several hours yesterday and made no headway, probably something simple I'm missing
Old 05-31-2011, 03:23 PM
SAIGON 68
johnnywishbone's Avatar
a new Porsche is supposed to be a pleasant experience. if i had your car, i think i'd be trying to get my money back. jmho
Old 05-31-2011, 06:44 PM
pmillikin's Avatar
Cory -
I feel your pain. Best of luck and here is a quick picture. At top right the Blue & Blue/Red are capped together and black wire is connected to the fuse block (blue wire)
86 Carrera #178
Old 05-31-2011, 09:16 PM
