KFJ_SC's Avatar
Unhappy 915 Rebuild problem
So I just finished reassembling my transmission - did everything by the book/posts (thanks to MarcA, rcale, JW, et al) checking and rechecking detents, etc.
I'm bench testing the shifting and seem to be able to engage every gear (good). Figure I'd twist the input shaft to make sure I can drive the axles and uh oh, won't turn in gear. In neutral I can see both input and output shaft turning through the access panel, but as soon as I engage any gear, nothing moves. So...what did I do wrong???
Kirk J.
78 SC euro
Old 08-28-2007, 09:25 PM
maybe it was left in reverse when the 5th/rev shift sleeve/fork/shaft was installed. does it ever get neutral?
206 637 4071
Old 08-28-2007, 10:43 PM
KFJ_SC's Avatar
Dagnabit - I think you are right (as usual). I pulled it out of 5th when I put the nose on, but in retrospect I think I pulled it into reverse. I'm probably not catching 5th/reverse when I go through the gears. Thanks (again)!
Kirk J.
78 SC euro
Old 08-29-2007, 05:04 AM
remove the backup light switch and pop the actuating pin inward.
206 637 4071
Old 08-29-2007, 07:12 AM
