CDI box rebuilder
Does anyone reliable repair the 3 pin CDI boxes that Bosch made for the early 911 cars? The box I have makes the proper whining noise when you turn the key on, but the car does not start. Another box, car runs fine.
Rick,
All REAL Porsches use Kettering ignition. :) Anyway, I don't think Pelican offers this service anymore, try OTTO in Venice http://www.ottosvenice.com/ or Loren at www.systemsc.com, don't mention ignition advance. :) Weird that the box whines, that tells you the inverter is working but if she don't spark, she don't spark. |
I just always have a 3 pin cd box around to check no start problems. If no spark at the plugs, then plug in a known good box. If it runs, then your done. Please tell me about the Kettering ignition.
Give Loren a try at www.systemsc.com.
Rick, LOL, Kettering ignition is the original battery-points-condenser-coil ignition invented by Charles Kettering in 1909. It's the system used in all pre-1969 Porsches and detailed extensively by Yours Truly in this thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/252299-before-there-bhkz-swb-engine-electrics.html |
| All times are GMT -8. The time now is 02:46 AM. |
