ianc's Avatar
Carrera Headlight Upgrade
Hey folks,
When I had my SC, I did a very labor-intensive H4 conversion, thinking I was being commendably thorough as indeed I was...
My H4 Project (Long w\ pics)
I was well pleased with the result, but how many times can you go through that? With my Carrera, I just wanted a simpler solution; and so decided to see what I could do as far as improving the existing H5's. Relays and higher wattage bulbs were an obvious start, so I began with that. I would use the same basic design as with my SC:
I grabbed a relay kit from Marcus Sucro and ordered a couple of 80\100 H5 bulbs from our host. The Sucro kit is very good, but after examining the default wire layout, I decided to rewire it. So much for convenience... I did this because I wanted to use thicker cabling than Marcus provides, and because in keeping with the above drawing, I wanted to use one relay for H and one for L. The result:
I used a permanent blk magic marker to stripe the H and L relay connections (86) to differentiate them from the power cables (87) since they are the same color but smaller. At right is a 30A circuit breaker from www.waytekwire.com to be installed inline from the battery.
Here is the result:
All ends are tinned and all connections soldered and heat-shrinked. Wiring should last awhile, so let's see if the stock plastic bulb connectors can handle the heat...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 08-28-2007, 10:14 PM
looks clean imo.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-28-2007, 11:43 PM
Thrlls's Avatar
Need a picture of the additional brightness acquired through this process!
Woody
Slow n Fast
1984 Guards Red 911 Carrera
Old 08-28-2007, 11:54 PM
Green Skull 006
Jim Garfield's Avatar
Nice job.
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 08-29-2007, 05:09 AM
MIK911's Avatar
Very nice. Did you upgrade the wires to the headlights also? If so, what gauge and how do you recommend doing this?
I've got the Sucro relay installed, but not sure how/which wires to upgrade
thanks
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 08-29-2007, 08:53 PM
ianc's Avatar
I did not do that this time as it is a helluva lot of work. I did do it on my SC however. Check out the link in my first post in this thread for more info,
ianc
Old 08-30-2007, 07:58 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Good stuff, Ianc, remember this thread?
There's plenty out there to keep the Carrera guys busy looking for candlepower.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 08-30-2007, 08:26 AM
ianc's Avatar
I do remember that thread; it was a very interesting one with plenty of lively discussion.
Unfortunately, I haven't seen too many like that lately...
ianc
Old 08-30-2007, 09:25 AM
dshepp806's Avatar
Marcus' stuff did the trick..great guy......
my car is better now, having engaged him and his product.
Thanks, Marcus!!
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-31-2007, 12:10 PM
