-   -   what boost limit for track days? (http://forums.pelicanparts.com/porsche-911-technical-forum/364868-what-boost-limit-track-days.html)
fredmeister 08-31-2007 02:57 PM
How much boost is ok to run for track days? I am contemplating installing a 1.0 bar spring in my 1979 930 and the only mods to the car are the following:
K27HFS turbo
GSF exhaust headers
B&B intercooler
stock Porsche wastegate
stock CIS with no other fuel enrichment devices.
AM I asking for trouble or will a 1.0 bar spring still not be too much for hard track driving?
Need some real experienced users to chime in as I do not want to find out the hard way that this was a bad idea.
Thanks,
Fred
bornrich 08-31-2007 03:40 PM
When you leave two black stripes from the exit of one corner to the entrance of the next you have enough boost. :D (Paraphrase Mark Donahue quote).
Steve@Rennsport 08-31-2007 03:42 PM
If you use that 1 bar spring, you need to use 100 octane unleaded race gas, for sure.
I would STRONGLY suggest that you check your AFR's before doing the DE event, too. :)
rattlsnak 08-31-2007 06:48 PM
i ran a 1.0 spring for many, many hard track days (a few years), as do just about every other turbos out there and never had a problem. As steve mentioned, make sure your AFM is right and you use high octane.
