limble's Avatar
engine not turning over 79 SC
The facts(?)
I went into a store for 15 minutes
When I came out the engine did not turn over.
The horn honked.
The battery seemed strong because with the ignition on
the radio/CD player worked.
The voltmeter showed over 12 volts.
I switched off the CD player and still did not turn over.
I let the car roll forward and let out the clutch in gear.
Twisted the key and the engine turned over and started.
The voltmeter shows 13+ volts while the car is running,
Went home (1 mile) Pulled it into the garage. Turned it on/off several times and it turned over and started easily.
This has happened before.
Could it be the ignition?
Or the starter?
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 09-02-2007, 12:42 PM
Scott R's Avatar
You're describing the exact situation I was in right before my starter went out.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 09-02-2007, 02:07 PM
Transplanted User
mkossler's Avatar
I'm thinking ignition switch first, starter second.
Matty K. - 82 SC Targa - SCWDP member #0052
"Racing - the sport that requires more than one ball to participate"
Old 09-02-2007, 02:20 PM
limble's Avatar
I should also add that when I turned the ignition there was no spring to it. So I'm thinking ignition switch. I have a spare, so tomorrow in it goes.
Thanks,
Mike
Old 09-02-2007, 08:41 PM
Something similar happened to me recently. Went on a long trip(mostly freeway with some rain), stopped for gas on the way back and the car refused to crank at all. Everthing electricly seemed Ok and the car started instantly with a short push. Got it home and it still would not crank. Came out later after the car had cooled and it cranked no problem at all. Its been fine ever since but now I don't quite trust the car.
I was thinking solenoid perhaps or starter itself
'83 SC Coupe
Old 09-03-2007, 02:30 AM
I'd suspect the starter/solenoid first because of the bump start scenario and the fact starters tend to fail more often than switches. Your comment about the spring in the switch, though, makes it a different situation and since you have a spare, replacement makes good sense. Just be prepared for a repeat of the start failure.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-03-2007, 08:08 AM
Designer King
Paulporsche's Avatar
As these things age, and then get hot , they seem to want to stick. Sometimes hitting the starter w/ a hammer frees things up. They can also be taken apart and cleaned. When my starter began doing this w/ 175000 mi on it I decided to replace it w/ a new hi torgue model.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-03-2007, 08:10 AM
