Turbo "chirp" when shifting
What is the "chirp" "chirp" noise I hear when some turbo cars shift gears? Why don't I hear this with the 930 when they are shifted, is it because the pop valve is not vented to atmosphere? Thanks. Len :) OOPS, wrong forum. Sorry guys, this should be in the Turbo forum. Mr Moderator, can you move this please? Len :o |
You'd be surpised, I suspect you'll get an answer from here just as fast. There are lots of turbo folks around.
you've probably got a bird joyriding on your antenna yelling F**K YEAH! everytime you shift:D
You're hearing the BOV (blow-off valve). The BOV on our Infiniti's supercharger is a dead give-away.
930's re-circulate the air back into the intake. Thus it does not go into the automsphere and make the noise.
| All times are GMT -8. The time now is 11:23 AM. |
