teveo's Avatar
MSD install, how to get the tachometer running?
Hi, I just made a MSD install in my 74 Carrera, very happy with the install and though I have not tested under normal operation there is a big difference in ease of starting.
My setup
MSD 6AL
New magnecors 8.5 wires
MSD tach adaptor
I checked the '73 diagram on Pelican tech info center and it seems that the black with purple is the cable that go to the tach.
I tested the MSD tach output and it gives a signal, but when hooking up the cable that sit in the big connector ( close to the old CD box, under the plastic cover left side of engine ) I get no reading on my tach.
Any information or advice ?
"old cars and bikes"
== System architect & developer
Old 09-10-2007, 09:10 AM
Hi:
I too, have a '74 Carrera,...(since new)....
Plug the black/purple wire directly into the tach terminal on the end of the MSD box and you'll be good to go.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-10-2007, 09:20 AM
