Engine stalls at idle when A/C on
Still getting the bugs worked out on my wife's '78 911SC. There's a bunch..
When the A/C is on and I let off the gas, like at a stop light, the engine stalls. I searched and could only find info to suggest that an overfull/ overpressure system may create excessive drag and cause this. Not sure if I can use a tire gauge to check system pressure or not.
Any thoughts, ideas or solutions welcome.
Old 09-05-2007, 05:05 AM
Engine stalling after letting off on the gas is a sign of running rich.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 09-05-2007, 05:12 AM
JBO JBO is offline
You may just need to increase the idle by 200 rpm's during the summer months when using the A/C - these cars don't auto. increase the idle when the A/C is on as most cars do. I do this then turn it back down to 950-1k rpm in the fall. If it does it with the A/C off or hunts for idle, as Rex says that may mean it is running a little rich.
Old 09-05-2007, 07:41 AM
Thanks for the input.
I don't think it's running too rich, it only occurs when the AC is on, but will search for rich/ lean diagnostic stuff. It drops to a consistant and smooth idle when the AC is off.
As for adjusting the idle up a notch, is it simply a throttle stop screw adjustment, or something more involved? My Bentlys book is in the car right now and my wife is out driving it.
Old 09-05-2007, 06:38 PM
Scott R's Avatar
Could be the compressor going out, if it's the OEM York the bearings and pistons start to seize over time, if the system was not evacuated correctly and water is mixed in with the oil. How hard is it to turn the outer wheel by hand? This was the case with mine, had been sitting exposed for a while and started to rust, they can be rebuilt DIY for a small amount of money.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 09-05-2007, 06:49 PM
Designer King
Paulporsche's Avatar
Unsafe,
Don't mess w/ throttlestops for rpm adjustment. Check the Bentley's or this BB. Use the large flat screwhead @ the side of the throttle area.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-06-2007, 05:23 AM
Thanks all. Found the appropriate idle adjustment screw and was able to adjust with fingers. Idles just a hair under 1K RPM and no more stalling!
Now on to the other 49 bugs to fix....
Old 09-06-2007, 04:04 PM
