the head ports look just like Johns(disfin) did. Looks like a used crack pipe, I imagine.
Sorry for the pessimism Dave. Obviously I don't have the details, but with those leak down numbers and the amount of oil that's making it's way into the combustion chambers it's my guess. Maybe it's all valves and guides. Maybe you'll get lucky, I never do. I'll be curious to hear how the pistons and cylinders measure.
[QUOTE=charleskieffner;3473161]
powder coat engine tin/fan/etc. it goes on and on............. cad plate fan housing strap cad plate all nuts bolts washers (cheap) QUOTE] Not to hijack this link, but I thought a top end was around 5k? Patrick quoted me that price when my 3.0 eat a piston ring? Chuck do you know of a shop that does this in Az? I am thinking of doing and engine drop to clean the engine up and fix leaks |
It's now under the "Thread Tools" at the top... took me awhile to find it too. Too early for the P & C debate until they are measured. 400mile/qt is alot of oil - better to do this now than to wait until you drop a valve... |
Can't always count on what the eye sees in the exhaust ports as far as buildup goes. If someone runs some Berryman B-12 or Techron in there, those big globs would be gone and you'd think everything was decent- except the port showing oily film/wet versus big glob of crud. Hence the reason oil consumption is a good gauge to go by.
My car had 78K on the clock and both the intakes and exhausts were goners, along with heavy wear on the rockers and shafts. Oil consumption was high and so was the valve clatter. No sign of oil staining in mine like oil changes may have been too infrequent or low quality oil usage. |
[QUOTE=KTL;3491253]Can't always count on what the eye sees in the exhaust ports as far as buildup goes. If someone runs some Berryman B-12 or Techron in there, those big globs would be gone and you'd think everything was decent- except the port showing oily film/wet versus big glob of crud. Hence the reason oil consumption is a good gauge to go by.
QUOTE] At least two of them were wet and oily. |
Dave,
Like donnie mentioned, your exhaust ports look like mine did. Here is a before and after picture. The head work was done by Bob at Anchor Atlantic in NJ. Based on your smoke on decelleration, you will correct the majority of your oil consumption by doing the head work alone. Rings are a good idea too. Remember, sloppy valve guides will create oil consumption issues, but not the compression/leak down issues you are having. My p&c's measured in spec and i hope yours will too. Good luck, and keep the pictures coming! John http://forums.pelicanparts.com/uploa...1190494327.jpg http://forums.pelicanparts.com/uploa...1190494345.jpg |
cams, cams, cams, cams. Get a 964 grind on your cams. Time for new valves. Expnsive I know, but at least do the exhaust. I hope he is going to pull the pistons and mic the lans. If OK reuse your cylinders and rings. Have the pistons bead blasted. Heads too. It is only money but you will be happier in the end.
So Dave,
how did the top end rebuild turn-out and what was the final cost? |
nice thread. not to hijack, but what is wrong with castrol oil? i just changed my oil on a mew to me 89 911 and i used castrol 20/50.
thanks |
super duper dave keeps us posted.
fender guy the two i know are patricks and jack at stuttgart. take your pick. or my buddy nels if hes not building vintage bug vans or off road porsche motors. |
I know it is long but well worth it. |
well its been a long time - waaayyyy too long. She should be on the road tomorrow. This is what she looks like today. Sorry about the pic quality - all i had was my phone.
http://forums.pelicanparts.com/uploa...1193676619.jpg |
Purty!
You got lucky on the Ps and Cs? I take it they were in spec.?
Midnight mumbling... I wonder if a can of sea foam or some diesel in a tank would help? Anyone knows?
Well my top end (plus extras) is now complete and I couldn't be any happier. Its killing me to take it easy on it for the break-in. She purs like a kitten!!!!
Here are a few before and after pics. http://forums.pelicanparts.com/uploa...1194048206.jpg http://forums.pelicanparts.com/uploa...1194048238.jpg http://forums.pelicanparts.com/uploa...1194048274.jpg http://forums.pelicanparts.com/uploa...1194048309.jpg http://forums.pelicanparts.com/uploa...1194048346.jpg |
Okay, after seeing these pictures, I just had an engine O.......
Un-be-liev-able! So, what was the final damage (i.e. cost)? |
20K! I am so ashamed!!!!
Beautiful engine BTW. Don't sell the car. Scott |
Thanks for the clarification! I'm happily single, so the figures didn't make sense to me:D For $7k, it's sounds very reasonable for all the work done!! Congrats!!SmileWavy |
Super_Dave_D:
I know what you mean about keeping the wife happy!! These young folk will figure it out someday. Ha. I just got done buying her a new stove and some knitting projects for the Winter months. Good job with the engine and cost controls. Thanks for this very informative thread and all the wonderful pictures of your hard work. Ah....now to REALLY enjoy the fruits of your efforts. |
:lol: I was wondering what you did on the top end for $20k :lol:
Wow that looks great! Excellent detail work on that engine
Wow, the engine turned out really nice. Now enjoy it!
That is BEAUTIFUL! If it runs as good as it looks I bet you can't wipe the stupid grin off your face!
The coolest part is that it doesnt pose as a bug fogger when I start it up! |
Engine looks beautiful.
Just curious if you did the P&Cs too or were they in spec? |
Dave, are the parts powdercoated red & silver? And if so do you know what quality powder it was, urethane, TGI, polyester, acrylic? I'm asking as my engine is torn down for a top end and I also want to spruce up the engine
Thanks, btw... BEAUTIFUL engine!! |
super duper..............hows the engine? havent heard an up-datum??? how many miles?
have you done anything to it yet? oil change re adjust valves? |
| All times are GMT -8. The time now is 10:22 AM. |
