-   -   Easiest, Most Secure Way To Jack Up a 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/366503-easiest-most-secure-way-jack-up-911-a.html)
911pcars 09-13-2007 11:28 AM
If you need a sealant for tapered threads (pipe threads), use PST; made by Loctite. It contains teflon, but is not a solid like tape that can block an oil passage. Recommended by Carroll Smith (Design to Win, etc.).
Sherwood
http://members.rennlist.org/911pcars
eR1c 10-08-2007 03:33 PM
how man quarts do we typically need for a transmission change? I believe I have the 915 transmission, ('77 930).
I was going to order the swepco trans oil from PP's and do the change on the next rainy weekend (when It's too crappy out to go driving).
911pcars 10-08-2007 04:58 PM
Purchase the gallon. You'll have some left over to store for the next XX years.
Sherwood
ianc 10-08-2007 06:22 PM
TERRIBLE IDEA. Not more than a week ago, Jim Sims posted on the danger of this -- it allows small bits of plastic to get into and clog the tiny oil passaes in the motor.
How on earth are you going to get bits of teflon tape in the motor from putting it on the trans fill\drain plugs?
Not that it's a good idea mind you...
ianc
burgermeister 10-09-2007 03:01 AM
ianc
It could be carried by an African Swallow. It could grab it by the husk. As the motor and tranny share the same compartment, the non-migratory nature of the African Swallow is not an issue in this case....
RWebb 10-09-2007 02:21 PM
cute - and I apologize for the typo
- the principle still stands however -- there is no need to use teflon tape and you are liable to get it inside the unit you are working on, with varying degrees of trouble being caused.
Noel 10-09-2007 02:23 PM
I prefer to lift the entire front of the car using the beam behind the AC condensor and the fuel tank. Use a large piece of wood between the chasis and the jack. Place jack stands under the rear torsion bar caps prior to jacking up the front, then lift the rear using a piece of wood under the engine and reindex the jack stands. Been doing it this way for many many years.
