PeterTarga's Avatar
Area under pedals threatment
Hi,
After the restoration of my pedal-cluster, i want to cleanup the floorboard but for the moment i want just do the area under the pedals, later on i can do the rest.
You can see here the progress for the cleanup, but what are the next steps to do, how far should i go with the cleaning should i remove all the rubber protection of the weldings ?
I have POR15 at home black and silver also metal ready and marine clean, i have also a product of 3M (rubber) for the weldings.
I must mention that I'm a beginner.
Thanks,
Peter
Old 09-13-2007, 02:00 PM
petrolblue83911's Avatar
From what I can see it looks like you have done quite a bit, -I did a similar job on my 914 a few yrs back, and had great luck with POR15, I used the gun metal grey color, and later re-painted over it. Since you will never see this area-I think the main thing is to get any residual brake fluid off of it, and then cover over any surface rust. The POR15 held up very well in my case.
Old 09-13-2007, 04:57 PM
DanielDudley's Avatar
I would clean the sealant out of the seams. If you have a dremel style rotary tool, I would use a tiny wire wheel to clean the rust out of the seams. Por 15 is a great choice. Tape off the threads before painting. I doubt you would need any seam sealant after two coats of Por 15.
Old 09-13-2007, 05:21 PM
19 years and 17k posts...
azasadny's Avatar
Great work, I'd also use POR-15.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-13-2007, 05:44 PM
Por-15
Marv Evans
'69 911E
Old 09-13-2007, 07:05 PM
