GaryR's Avatar
Send a message via ICQ to GaryR
Tool search - 36mm crowfoot for oil lines
I can't find this darn tool online from US suppliers...
Thanks for any leads..
Gary R.
Old 09-10-2007, 06:03 AM
That'll be tough. You may be able to use a 1 3/8" crow's foot. The difference in size between the two is .042" which is probably less than the manufacturing tolerance.
The biggest pain between the crowsfoot pictured above and a standard crow's foot would be the fact that the one above is like a 12 point socket giving you fewer degrees between ways that it will fit on the nut and a standard is like a 6 point.
Have you checked Pelican to see if they sell it?
Old 09-10-2007, 06:17 AM
Friend of Warren
I've always just used two big adjustable wrenches. Never had any problems with rounding. Always used lots of PB Blaster first.
Kurt V
Old 09-10-2007, 06:20 AM
Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
I got mine from Mcmaster.com
http://www.mcmaster.com/
Go to page 2721 in the catalog.
I don't remember if I got a 1-3/8 or 1-7/16. I can look tonight when I get home if you like.
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 09-10-2007, 06:32 AM
GaryR's Avatar
It must be 1-7/16" as 1-3/8" is 1.375" and too small.. The wrench in the picture is from a UK distributor, think it's made by Stawhile (sp?).. about $115!
36mm = 1.4173
1-7/16" = 1.4375
A 1-27/64" would be closest as 27/64" = .421875 but that doesn't exist...
Gary R.
Old 09-10-2007, 06:38 AM
Stahlwerks.com
jhelgesen's Avatar
Sorry, the metric ones only go to 22mm.
I've used large adjustable wrenches and even my suspension adjustment wrench in a pinch. Only time I needed the crows foot was to get a line off the oil cooler thermostat (and it worked great!)
What are you trying to do with it?
John Helgesen
Old 09-10-2007, 06:50 AM
GaryR's Avatar
It makes getting at the thermostat oil lines VERY easy and I just wanted one in my toolbox rather than borrow my shops...
Gary R.
Old 09-10-2007, 06:53 AM
Senior Member
i got mine off a snap on truck - was around $40 if I remember correctly
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 09-10-2007, 06:54 AM
GaryR's Avatar
And it's 36mm? Snap-On site doesn't show them..
Gary R.
Old 09-10-2007, 06:58 AM
Senior Member
inch equivalent - was a perfect fit will have to look at it when I get home
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 09-10-2007, 07:35 AM
36 mm Crowfoot
Go to:
sjdiscounttools.com
Old 09-10-2007, 08:00 AM
36 mm oil line wrench
sold by Pelican, why isn't that the tool for the job?
Tom
Old 09-10-2007, 08:34 AM
Stahlwerks.com
jhelgesen's Avatar
It's just about impossible to get any other wrench into this space....
The crowsfoot on a ratchet handle can get in here.
John Helgesen
Old 09-10-2007, 08:45 AM
Recently Disbanded
juanbenae's Avatar
i special ordered mine from a mac tool truck dude. still took a couple weeks.
T$
Old 09-10-2007, 09:26 AM
AutoBahned
RWebb's Avatar
drop the whole thing as a unit and then use whatever on that nut
Old 09-10-2007, 10:44 AM
Autodidactic user
David E. Clark's Avatar
If you don't mind off-brand tools, V-8 Tools makes this Jumbo-Crowfoot Wrench Set that goes from 20mm - 46mm (including the 36mm) for $82.97 for the entire set. No affiliation so I can't vouch for quality.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 09-10-2007, 10:57 AM
GaryR's Avatar
Those won't work the way I want, has to be a 12pt as shown in the picture.. and RWebb, I could also just cut the line at the nut and use a 36mm socket on it, but that has nothing whatsoever to do with anything does it...
Gary R.
Old 09-10-2007, 11:01 AM
AutoBahned
RWebb's Avatar
do what you want - it is easy to drop the whole unit, and that will allow cleaning & inspection.
Old 09-10-2007, 11:02 AM
safe's Avatar
This is a cheap 36mm wrench that I bended and cut open. No problem with access on a narrow body car.
Magnus
Old 09-10-2007, 11:41 AM
Now that is inventive. Nice job.
Old 09-10-2007, 01:48 PM
