Quick K&N question
I just replaced the K&N cone filter set up on my 87 3.2L to the stock air box.
I am using a K&N filter also in my air box. The car ran fine prior to the swap, but now the idle is a bit rough. I have checked for all vacuum leaks and am confident I have gone over everything. When I place my hand over the air box opening however, the idle smooths out. ???? So, could this mean the K&N needs more oil applied? It had been sitting in box for 5 or 6 years prior to me using it.
Hopping this is a simple fix...
Old 01-18-2009, 06:59 PM
OK, figured it out. This was an autothrity system. I have to replace the chip too.
Thx all.
Derek
Old 01-18-2009, 08:30 PM
burgermeister's Avatar
If it is a hot wire system, do be careful with the K&N oil. If you get oil on the hot wire from over-oiling your filter and running the car, it can ruin the MAF sensor.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 01-18-2009, 08:41 PM
roodog911's Avatar
+1 on over oiling ...
"Circumstances may cause interruptions and delays, but never lose sight of your goal." Mario Andretti
'84 Targa
Old 01-18-2009, 09:23 PM
