Jupiter 911
Bosch Platinum +4 Plugs
Gents can you advise if the Bosch Platinum +4 spark plug I have installed in my 87 Targa 3.2 are a good choice. I have a SW chip, KN air filter, cat bypass and a Bursch performance muffler. The vehicle runs great but I hear so much about NGK and other plugs. Can anyone advise if I should change? And if so to what and what brand and number?
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
NGKBPR6ES There's been some discussion related to platinum plugs if I rememeber correctly and it has mostly, if not all, been advised against using them.
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
Member 911 Anonymous
DO NOT USE PLATINUM. I had the +4's , they do not start the car immediately and at times causes miss-fires.
If you are going to go exotic, try the NGK Iridiums, I just installed them and they are amazing. But stick to OLD SCHOOL NGK's "ES" if you are anywhere a bit skeptical. .02
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I've run Bosch +4's for about 3 years or so with no problems. My car starts immediately and doesn't misfire...
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
I put NGK iridium's in my M# and had two of them fail. The iridium tip came off. Fortunately the tips seem to have blown out the exhaust without damaging the engine. I will give them credit though, NGK was going to repair any engine damage done by their plugs failing.
83 SC CAB 98 M3 87 944S |
Interesting. I installed NGK Iridium in an 85 3.2 and have had the same experience as Draco. They have been great. But now I'm going to worry a bit about the tips coming off!!
RETIRED
Platinum plugs suck......
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I was too a big advocate for the +4 but While I was in there changing out my injectors, I wanted to compare and oh boy what a difference. PM me and I will tell yeah what I paid for the IR's
I have been happy with the Denso iridiums (IW20). My theory is I want the plugs to fire at the lowest possible voltage to reduce stress on the HV components of the ignition system. Therefore I want the sharpest possible plug tip.
Scott Wilburn 1988 911 Carrera 3.4 L 1998 M3 1984 308 QV |
Jupiter 911
Thanks Gents, plan to go with the NGK soon.
Jupiter 911
If I go with the NGKBPR6ES, what should the gap be set at?
I had +4's installed from PO. I replaced them with the old fashioned copper (no idea how long the platinums were installed - but I am a firm believer in at least checking the plugs at every valve adjustment, if only to prevent seizures and have a look-see). No difference whatsoever in how the car ran.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Per Bentley 0.028-0.032 inches, Iridiums are "pre-Gapped"
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 01-18-2009 at 09:19 PM.. |
