LinkBack Thread Tools Rating: Thread Rating: 26 votes, 3.77 average.
A 40 weight straight grade has the same viscosity characteristics as an 85W gear lube. It is way too viscous to run in your engine during the winter months in LI.
Even a 20W stops pumping at 5F. If I were to drive my 911 during the winter, I would not going any heavier than a 10W. I'm not sure if you would be able to use a 10W30, or if you would need to go up to a 10W40.
There are some very bright guys on this thread-what would you recommend?
Jon
Old 11-17-2008, 05:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1041 (permalink)
There is no need to run a straight weight - the only time I ever have a customer run a straight weight is for the break-in oil (only comes in a 30wt) and in a race car that has pre-heaters for the oil (i.e. dry sump tank heater) so the oil is already up to temp when the engine is started. With sustained extreme heat (>=300F), a mono-grade holds up a bit better, but you shouldn't be experiencing that problem.
The Brad Penn guys say their 20w50 is good down to 20F cold starts, and from my experience in my own 911, it's good down to about 10-15F, like the owner's manual states for those operating ranges.
It is not a problem switching from a synthetic to a non-synthetic or vice-versa. Sometimes going from a non-syn to a syn might result in the appearance of new leaks (which are likely old leaks that have sealed themselves).
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 11-18-2008, 06:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1042 (permalink)
Originally Posted by cnavarro View Post
The CI-4 Rotella T recommended in the article does not even exist - it's been replaced by the new CJ-4 version.
I haven't looked, but the Shell web site still indicates its existence...
http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/products/zzz_lhn.html&FC3=/rotella-en/html/iwgen/products/product_rotellamulti.html
Old 11-18-2008, 07:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1043 (permalink)
If you try ordering it through a lubricant dealer, they come back and say it's no longer sold and is superceded by the CJ-4 version. I tried this back well over a year ago, all that is left is old stock. The syn version apparently is still CI-4 or at least what I have available around here is old stock. I wouldn't count on it being available for ever either.
Charles Navarro
Old 11-18-2008, 08:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1044 (permalink)
Thus my own personal dilemma. I've got a 41K mile car with ZERO oil leaks; I mean, this engine is as dry as a popcorn fart! Service history indicates Castrol GTX 20W50 at least every 3K miles since new. 4% leak-down on all cylinders from recent PPI. Upcoming oil change in less than 200 miles, Case of Brad Penn 20W50 sitting on my garage floor, and my two most trusted master Porsche mechanics (both worked for Porsche, one in Stuttgart) are BOTH telling me: "Keep running the Castrol GTX 20W50..." I waded through this entire thread, and I see cars on both sides of the "I switched to Brad Penn and it leaked/didn't leak..." fence. I'm willing to give the BP a try, just don't want it to start irrevocably leaking...
Old 11-18-2008, 08:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1045 (permalink)
MBruns for President
JeremyD's Avatar
My car had pretty religious oil changes with Castrol GTX 20W50. At 56,000 miles I needed valve guides so opened up the engine. The case was stained amber colored from the castrol. The lay shaft bearings were at cooper. The cams were pitted and several of the rocker arms were out of spec. It didn't leak oil though - I guess that was nice.
Old 11-18-2008, 08:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1046 (permalink)
That accurately describes my experiences with Castrol GTX 20w-50.
I couldn't bring myself to use it in a lawnmower,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-18-2008, 10:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1047 (permalink)
Thanks for the helps guys. I'm def gonna switch out of straight 40. I was looking into the Brad Penn oil probobley get a case of that. I also was looking at the swepco. Which one do you think I should go for?
Also is this the BP oil.
http://cgi.ebay.com/ebaymotors/BRAD-PENN-20W-50-RACING-MOTOR-OIL-THE-GREEN-OIL-CASE_W0QQitemZ260305166386QQcmdZViewItem
1988 Porsche 911 3.2 (cat delete, K&N drop in filter, chip)
Old 11-20-2008, 06:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1048 (permalink)
Jupiter 911
bklyn's Avatar
Mobil 1
Try Mobil 1 15w-50 its awesome, stop with the leaks it does not happen, ifs its going to leak its going to leak!!: Dont blame the oil, it just might be your engine.
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 11-22-2008, 01:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1049 (permalink)
calling on Charles
OK, I'm currently using Mobil V-Twin. Should I change to Brad Penn?
Rob
356robo
70 T Targa
Looking for a 2.2,2.4, or 89 coupe
Old 11-23-2008, 07:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1050 (permalink)
Large Registered Member
PatrickB's Avatar
Rob
Perhaps you should consider reading the previous 1000 posts on this thread?
I used Mobil1 V-Twin for several oil changes. I'm now using RedLine 20w60 Motorcycle Oil with even better results. Check out Charles' web site too! He's gone above and beyond the call of duty volunteering test results of MANY different oils!
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 11-24-2008, 12:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1051 (permalink)
ShakinJoe's Avatar
Jeremy
What are you using now??
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 11-24-2008, 03:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1052 (permalink)
Why is picking the right oil so hard haha....i think I'm just gonna go with brad penn's 20W50 for the winter...I read on his site that the 40 is good for older engines and air cooled engines but might not be good to run in the winter since I'll be running it in 30 degree weather.
Old 11-24-2008, 11:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1053 (permalink)
JeremyD's Avatar
Originally Posted by ShakinJoe View Post
Jeremy
Brad Penn - just changed the oil this weekend - figure I would be good to my car since I've run so many track days this year.
Old 11-24-2008, 12:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1054 (permalink)
The Motul semi-syn 15w50 is next on my list to test, as it's easier to find in Europe and would make a great choice I would think. Having an ACEA A3/B3 approval is a plus for sure. Means a lot more to me than an API rating for sure. Overall, I'm very pleased with Motul's products as a whole, albeit they are very expensive in the US.
Charles,
Motul has a 300V Le Mans 20W60 that probably also warrants some test considering the Castrol TWS 10W60 you mentioned as a liquid rebuild.
'87 3.2 Targa
Old 12-09-2008, 07:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1055 (permalink)
dan79brooklyn's Avatar
Here is my oil analysis from Blackstone labs.
I have been running Mobil 1 Racing 4T 10w-40 (synthetic Motorcycle oil)
The oil tested had done year, 8,000 miles, and three track days....
Any comments on the results?
I changed the oil a few weeks ago with the same product.
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon
(new addition 1998 Mazda Roadster)
EX - 1993 Porsche 911 Carrera 2
EX - 1979 Porsche 911SC TARGA
EX - 1976 BMW 2002
Old 12-09-2008, 02:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1056 (permalink)
It's nice to see someone posted one of these UOA's up, it would have probably cut this thread in 1/4 the size it has become.
I would say for the mileage you went on the oil thats not too bad.
TBN looks great and generally Mobil1 seems to show higher iron.
Lead seems to be my only concern which seems a little high(bearing material?). I don't know if Porsche ever designed these engines to run 8k on a single oil change but I bet if you change it at 4 or 5K you would be fine.
Anyone want to chime in on the high Copper?
Otherwise seems like it's working great.
Old 12-09-2008, 04:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1057 (permalink)
Forced Induction Junkie
WERK I's Avatar
The lead content may be from Racing Gas during the track days.............maybe?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 12-09-2008, 04:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1058 (permalink)
I've never run race gas...The car does use a bit of oil, I probably added 5-6 quarts during the past year/8,000 miles. I know this was a long oil change interval, but didn't Porsche reccommend very long changes even prior to synthetic oils?
EX - 1976 BMW 2002
Old 12-09-2008, 05:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1059 (permalink)
Dan, that UOA looks great! Right in line with the UOAs that I have done.
Charles Navarro
Old 12-10-2008, 06:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1060 (permalink)
