CDI ignition troubleshooting
Picked up a 1973.5 911T. It ran when I got it, now it cranks but no start. Its getting plenty of fuel. No spark at output of coil. Getting correct voltage at CDI unit, but I'm not sure if its working. Also, it has the regular, smaller size coil installed, not the bosch super blue that it about .5" longer. I heard somewhere you are not supposed to use regular coils with this system? Is the CDI box gone?
Old 09-18-2007, 08:50 AM
Ohm reading on coil is fine, I even swapped to a super blue coil, no difference
Old 09-18-2007, 08:51 AM
jluetjen's Avatar
Misery loves company. I've been working on a similar issue for some time. You might find some ideas there.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 09-18-2007, 09:16 AM
ok, well I removed my CDI and I'm gonna switch it with a friends and see if there's any signs of life.
Old 09-18-2007, 10:39 AM
304065's Avatar
Does the CDI whine when you power it up? There's a noticeable high frequency (2Khz) vibration from the inverter section, sounds like a camera's flash unit (same principle too).
What's the coil part number? If you try to use an old-school Kettering coil you will fry stuff. The CDI coil IS smaller than the blue, so you might be in good shape there. Keep the blue on for now, though.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-18-2007, 10:54 AM
I can't hear it whine when the ignition is on, but for about 5 to 7 seconds after the switch is turned off, I do hear the "camera flash" hi pitched noise.
Old 09-18-2007, 11:02 AM
coil p/n is 0 221 121 001 then 912 under it
There is no voltage at the coil terminals (1, 15) with the ignition on.
Old 09-18-2007, 11:08 AM
304065's Avatar
0.221.121.001 is the correct coil for an MFI car. Is yours black or silver? If Black, OK.
As far as connecting your voltmeter to the coil terminals, if you want to destroy the CDI unit it is far easier to hit it with a sledgehammer. Although a sledgehammer can't give you a 460 volt shock like the CDI will.
Seriously, don't connect anything to the coil terminals.
So it doesn't whine when you put power to it but it does whine when you shut it off? What color wires are going to it? That's the reverse of what's supposed to happen, makes me think the wires are not correctly connected.
'81 R65
Old 09-18-2007, 11:27 AM
Early_S_Man's Avatar
Porsche Crest
Please discontinue your 'shotgun' attempts at troubleshooting until you have reviewed and understand the basic principles of CDI operation!!!
Have you ever heard why the probability of a kill ratio for a US Navy ASROC was 2.0 ... as in 1.0 for target, and 1.0 for launching submarine??? Thus far, you are the person on the launch button of the ASROC, a rocket-boosted, nuclear warhead-equipped torpedo ...
The theory of operation and basic testing are described in a Bosch document posted in the following thread:
History of Bosch CDI ... toubleshooting info, parts list changes, and schematics ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-18-2007, 12:30 PM
Umm....oops
Old 09-18-2007, 01:12 PM
HarryD's Avatar
Do you have the stock bosch unit or an aftermarket unit (permatune, msd etc)?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-18-2007, 06:03 PM
