Placement of Engine Stickers for 1971 911T?
Just want to verify the correct placement of the gold foil stickers in engine bay of a '71 911T.
Is this the correct order from right to left? ----- "Firing Order", "Valve Clearance", "Check Oil Level", "Tire Pressure", "Alternator" Thanks, Steve |
The sequence and identification you show agrees with the information shown in the Performance Product Summer 2007 catalog.
Al |
Stressed Member
Are there only 5? My E has 6 (don't remember the identity and placement of each).
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
The number depends on the year. For example, my 73T has only 5, but the 72T had 6.
My '73 (started life as a T)...hope this helps. The extra one second from driver's left is the PMO Weber conversion back in '77.
'73 911 Frank 'n Meanie 2002 Boxster S PCA Instructor Circa '95 |
My car is a repaint and appears to be missing the far left sticker, it's a 1970 911T. What is that one? Alternator?
-Jess |
Upon further review, Scott is correct. Again referencing the Performance Products summer 2007 catalog drawing of the gold foil decals as it applies to a '71. From Right to Left, with the applicable years for that particular sticker.
6) Firing Order (65 - 78) 5) Valve Clearance (65-89) 4) Engine Oil Level (65-72) 3) Vehiocle Capacities (70-71) 2) Tire Pressure 200km/h (67-72) 1) Alternator/Regulator (65 - 73) Al |
Far driver's left is for alternator.
