1981 911SC Targa
Charcoal Canister
If this is as important to hook up as I have been told why does the parts diagram show a plug in place of the vapor rated hose into the air box.
Does anyone know if the vapor rated hose is available through this site.
My canister is currently not hooked up but if it needs to be I thought the hose
would be shown on the diagram.
Thanks for any input
Old 09-19-2007, 06:01 AM
1981 911SC Targa
54 hits and knowone out there has an answer?
Old 09-19-2007, 04:55 PM
Stressed Member
Scott Clarke's Avatar
I recently purchased some hose from Pelican. I found it in the fuel section. I think that the hoses from the canister are the same diameter and type as those from the hard lines to the air cleaner/fan shroud. I was looking for a '70, so you might try the earlier parts diagrams. I don't know if the later cars had the same canister.
-Scott
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 09-19-2007, 05:16 PM
Grappler
Rodsrsr's Avatar
The charcoal canister is part of the smog system, and its mandatory in Cal, but I dint know about the "show me" state. Its supposed to help trap fuel vapors. I dint see why you couldn't just use fuel line.
Old 09-19-2007, 05:18 PM
sjf911's Avatar
OEM-N0203621 is the part number for the cannister to intake. It is listed as 12X2.5 hose. I just took my cannister down to NAPA and found generic fuel hose that fit. I think the hose from the tank vent might be a different size (larger?, but I can't remember), although it is listed as OEM-0203612 and 4X1.5 in PET.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 09-19-2007, 05:27 PM
Send a message via AIM to fintstone
You can plug it or remove it if you don't need it for emissions.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-19-2007, 06:25 PM
1981 911SC Targa
Thanks to all. Mine is currently plugged and seems to have no harmful effect on the state of Missouri as of yet. The reason I was inquiring about hooking this back up is that in a prev. thread someone had mentioned that if this is not hooked up it could cause a fire.....I think this is if the tank was not properly vented.
Thanks again!
Old 09-21-2007, 04:58 AM
I went to Autozone and got hose for crankcase ventilation. It should be OK for fuel vapors and plenty cheap.
Steve B.
1972 911t
1999 328is
Old 09-21-2007, 05:26 AM
cycling has-been
bkreigsr's Avatar
I think I remember a post/reply by Dr. Grady saying it's a very good idea to keep it in the earlier MFI cars.
Not sure if it applies to the 81 CIS systems.
Bill K
Old 09-21-2007, 05:34 AM
