Innov8's Avatar
Mega Squirt?
What are the advantages of the MegaSquirt injection system? I have a 3.0sc with a functional CIS system that I have started usung for AX and DE. What benefit would I see by upgrading to this system? Thanks!
04 996 AE (daily driver)
08 A3 Quattro
05 E500 Wagon
PO: 11 Raptor SCREW, 11 GTI 6sp mt, 01 Audi S4 Avanti, 95 Volvo 855 T5R, 82 911SC
Old 09-20-2007, 08:48 PM
Wer bremst verliert
JohnJL's Avatar
None if your CIS system is functional as you say. My opinion is MS is for;
1. Tinkerers who enjoy a challenge (thats me)
2. Builders of unique engines
3. Replacers of troublesome CIS, Carb or MFI who have "spit the dummy"
4. EFI installers investigating alternatives to commercial units
There isnt any compelling reason for your situation in my opinion.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-20-2007, 09:08 PM
I have read a lot about the Megasquirt conversions, and overall I agree with JohnJL's assessment. If you do it on the cheap (relatively speaking) and keep parts of the CIS intake, you may get a slightly smoother idle and slightly improved drivability.
OTOH if you spend a bunch more money and upgrade to individual throttle bodies, you should see significantly better throttle response (the engine will feel faster because it revs up more quickly). This also opens up the possibility of switching to hotter cams down the line, and that's when you see the real power gains.
The CIS system in my car works *almost* correctly but still has some rough spots during warm up. It appears that my WUR is changing the control pressure in a big jump rather than a smooth gradual change. Since this part is NLA from Porsche (for my year) some sort of change (carbs or EFI) is in my long term plan.
Good luck
Scott
1978 911SC RoW
work in progress
Old 09-21-2007, 06:44 AM
Scott R's Avatar
JohnJl is dead on IMHO. I did it because parts were becoming scarce, and I wanted a system that I could diagnose with a laptop. Now the benefits are that when I rebuilt my engine with higher compression, and hotter cams I could just dial it in from the front seat.
In your situation, why remove something that's working for you? CIS is fine when it's functional.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 09-21-2007, 07:21 AM
sjf911's Avatar
1+ It gives you enormous flexibility with the engine.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 09-21-2007, 07:37 AM
I went that route because my CIS was going to get real expensive with a bad fuel head. So decided to dump that and do tbitz MS kit. now my car is turbo charged after the fact so it has worked well for me
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 09-21-2007, 09:55 AM
