Bruned cap and rotor?
I was having some severe surging and hesitation issues since my rebuild, then it got worse. The search feature led me to a few dozen things, two items being the cap and rotor. I removed these last night and the inside was completely carbon tracked, and the points on the cap are burned and black, and the rotor tip is worn down to the plastic.
These parts aren't that old, probably a few months post rebuild and this has me worried. I did replace the cap and rotor with my spare and problems are solved. But what would cause this in such a short time? What else do I need to replace?
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Are you by any chance running an MSD box and extra-wide spark plug gaps???
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
MSD with the standard gap, any issues there?
Well, looks like your MSD found the weakest points in your ignition system, and went on 'full obliterate mode' attack! Wider gaps make it happen faster, still!
Now, just what was supposed to be the justification for installing an MSD box rather than just a coil switched by the MS?
