Door Latch w/Pics
My passenger door latch is non-op. The U-shaped part shown below now wobbles and therefore will not rotate properly when closing the door to secure or latch it.
This is a shot from inside the door. That's the window track in the way:
This is someone else's shot of the inside of the latch mechanism. The inside ( or opposite end) of the shaft with the U shaped part has the coil spring on it - ignore the red colored drawings:
Does anyone know how this piece is held together? Or how the shaft could come loose? How to tighten it up?
1972 911T/S MFI Survivor
Old 03-31-2008, 12:25 PM
I have not removed mine yet. I would like to tighten it in place if possible. I can still turn the latch by hand and the spring still engages - the shaft is just loose.
Old 03-31-2008, 12:26 PM
Throw it on the ground!
Have you checked your striker plate? The nylon internals get chewed up with wear and the problem may be there rather than the latch assembly. Do a visual comparison with the driver side strike plate to see if everything is as it should be. I had a little plastic piece fall out of mine the other day but it is still working (for now)
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 03-31-2008, 12:30 PM
Mark - I have compared the parts from side to side (at least that which you can see without removing another interior door panel anyway). The "broken" one has a great deal of play - as much as 3/8 of an inch of play - compared with the "good" one which has no play. And both strikers look the same.
Thanks.
Old 03-31-2008, 01:54 PM
I would rather be driving
jpnovak's Avatar
Make sure the three philips head screws that attach the door latch to the door are tight. If they are there is little you can do to the door latch. You will need to remove the door window frame and replace the whole thing.
The rotating part of the latch is behind the large clock spring. The shaft is the part that has the slot in the center of the spring. Under the spring is the catch mechanism that you see on the right side of your posted picture. There are two stops under the linear spring to the right. They look like a shark fin of sorts.
These are all pressed together into the backing plate for the latch. I don't think there is any way to repair them. I am surprised they wobble since there are no plastic bushings to wear out, at least on this part. Be aware the early door latches are slightly different than the late ones. The difference is the length of the lever arm that the interior door release attaches to and the locking arm.
Old 03-31-2008, 02:37 PM
Jamie - the three screws were tight - thanks for the reply.
Finally got the latch out and ordered a used replacement from Easy. I had to remove the track for the window, that was covering up the latch on the inside of the door. To get the track out I had to lower the window about half way, pull the track up through the top of the door, then raised the window again. A bit of the lift mechanism was still in the way but I was able to work around it. I will post a how to once I get the thing back together. It is amazing how far apart you must get the door to repair the latch. And even more amazing to me that it was the passenger side that failed.
Lastly, I do not know what failed. The shaft is quite loose, while everyone assures me there is no bushing/washer/grommet. Once I get the new one I will compare.
Old 04-02-2008, 10:23 AM
Follow Up - Final Pics
Latch failure:
Old 06-02-2008, 11:09 AM
Reference shots
This outer edge window track must be unbolted and pulled up and out of the door to remove latch
The track is pulled up and out of the door
Note the extra piece of steel welded to the chrome track - it gets in the way when removing the track.
Old 06-02-2008, 11:17 AM
Other reference shots
These holes are normally covered by rubber plugs. This is where the screws are that hold the window track.
Where latch lives
Inside the door showing lock rod
Old 06-02-2008, 11:24 AM
Cut outs for window switches? 2 on the passenger side????
Anyone know what this number is? It does not correspond to my VIN.
Back side of outer door pull
Ditto
I would recommend buying a few of the yellowish/white plastic grommets(?) - they get old, they're still available cheap, and you are likely to break one. They attach the rods together inside the door.
Old 06-02-2008, 11:30 AM
Latch Assembly
Where did you buy the replacement latch assembly?
HowTay
Old 07-22-2008, 08:59 PM
AutoBahned
RWebb's Avatar
2 holes on "pass. side" b/c in some countries it is the drivers side
good pics
these things are apparently just stuck together with little reinforcement....
Old 07-22-2008, 09:47 PM
I purchased the latch from EASY in Emeryville, CA. Tel: 510.653.3279
Old 07-23-2008, 09:38 AM
Followup: although the new latch functions perfectly, it apparently was an updated part as the mounting screw diameters increased. EASY sent me new screws gratis after I called them.
Old 03-18-2009, 08:23 AM
