lonewolf's Avatar
alluminum crossmember
great shape
130.00+ shipping
bruce930@telus.net
Old 09-20-2007, 02:12 PM
AutoBahned
RWebb's Avatar
Is it a forged one??
Old 09-20-2007, 09:41 PM
lonewolf's Avatar
not sure if forged or cast alluminum
out of an 80sc
Old 09-22-2007, 07:51 AM
lonewolf's Avatar
bbb
Old 09-22-2007, 07:58 AM
Those are cast. Only the '73-'74 RS cars had a forged one.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-22-2007, 09:48 AM
AutoBahned
RWebb's Avatar
thx - thought it might be a rare RS forged one b/c of the price
Old 09-22-2007, 12:42 PM
Grady Clay's Avatar
There are three choices:
- The OE steel cross member. There are two versions; ‘65-’67 and ’68-’73.
- The Forged ’72-> RS/RSR aluminum version (a race part and very expensive if you can find one).
- The ’74-> cast aluminum version.
There are pro and cons to each.
Since this part is to the front and low, I don’t think weight or CG is an issue in most situations.
The steel part (and forged aluminum one) strengthens the chassis in front. The down-side is you want the suspension to be more fragile than the chassis. It is desirable for the suspension components to yield (fail) before there is chassis damage. The cast aluminum part allows this (it is least expensive and readily available used.)
A desirable feature of the two aluminum components is there is more room for fuel pump and fuel filter alongside the cross member.
As any engineering situation, there are pro’s and con’s for every set of parts.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 09-22-2007, 02:58 PM
