starter wiring - question 2
In the picture below with the stock Bosch starter, how are the two yellow wires fastened to the post? Is it a bolt or something else? It is hard to tell from under the car.
All help appreciated.
1972 911T targa
Old 09-26-2007, 11:43 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I have seen both spade connectors and eye-style connectors that attach to a threaded post with an M6 nut. I believe the earlier cars use the threaded post style.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 09-26-2007, 11:55 AM
Early_S_Man's Avatar
Porsche Crest
The two Yellow #50 wires would have been on a Faston female connector, and a 0.25" tab would have been original from the factory, but, who knows after 35+ years! I have seen rebuilt SR-17 and SR-68 starters without a tab present on the solenoid M5 stud. The solenoid has M5 stud and 8 mm accross-the-flats nut.
BTW, one Yellow wire goes to the 'G' terminal [heater coil wire] of the Thermo-Time Switch on the oval breather cover, and the other goes to #1 terminal of the 14-pin connector.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-26-2007, 12:12 PM
midnight911's Avatar
my 1984 carrera with 3.2 and 915 was spade type connector.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 09-26-2007, 04:00 PM
peritus's Avatar
There are two places you can connect the ignition wire. Either work. Give me a shout if you have more probs. I had issues with my starter all spring, and finally bought a hi-torque from Pelican.
I have an extra stock starter if interested.
How was SE Asia? Do you still need my engine rebuilding book? Where has Steve been?
James
91 Black on Balck 964 C4 (DD)
82 Metallic Red SC 3.6 Varioram (sold)
Old 09-26-2007, 05:21 PM
