MSD with stock shielded plug wire's?
2.4 cis what are the best plug wire's to run with MSD I have heard that I could not run my stock shielded wires if this is true, what are the best ones to run? I have tryed an aftermarket brand but as much as I tryed to keep from pulling them apart they came apart when I changed my spark plugs. Any help with this will be greatly appreciated
Thanks |
go ahead you can say it, Jacobs - I made the same $100. mistake. I am currently using Firebraid wires with MSD and a Blaster coil. They are great, and you can check your plugs without having to rebuild half the plug wires.
-Mike D. '74 914-6 '94 968 |
Designer King
I recently got MSD wires when I put in the MSD box. I think they were for a Chevy 6. I've had them 2 years and they seem fine.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Paul, what did you do about the little screw on connectors on the Beru side?
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
