Anarchist Extremist
lightened flywheel?
Is it worth getting a lightened flywheel? do they enhance/hinder perfomrance at all? what manufacturer makes the goods.. etc etc.
thanks all Chris
80 SC Coupe 00 Tundra (Tow Rig) 00 Audi A6 Avant (wifes rig) 03 Wife ('71 typ Spezial) 05 Kid (MENSA prototype) |
fidanza,i beleive is the name.and yes they are worth it.i love mine.wind up quick,wind down quick!fun,fun,fun.
AutoBahned
define perfomrance ??
it will not add hp; it may add fun on the street it may subtract fun... esp. from a stop |
I just put the Patrick Motorsports RSR style flywheel in my 74 and I love it. The motor "feels" lighter and more willing to rev. Redline definitely comes on faster than it used to. It's not hard to drive in the least, but my engine has heavier internals than your 3.0 (3.2 crank, rods, and 100mm pistons).
1988 Carrera Targa, Guard's Red 1959 356A - long gone 1960 356B - long gone 1978 SC Targa, GP White - Accident - Totaled 2006 (T-boned by a nut on drugs) 2003 VW V6 Passat Wagon |
drag racing the short bus
I have a lwt flywheel in my garage. I'm wondering at what point, and how difficult it is to install. For instance, the transmission probably has to be dropped, correct?
The Terror of Tiny Town |
Less brakes, more gas!
Installation means pulling the motor. You need new flywheel bolts and then you have to torque them down so not very realistic to do it in car. Also, IIRC, in his book, BA does not recommend one for the 3.0+ in street applications. For smaller engines it is useful. See this thread: Fidanza lightweight flywheel; 911SC I am currently in the market for one. I'll look at Patrick and see what they have ![]() Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
I love my light flywheel. The damn car just winds up so fast with it. I may not be faster but I'm having way more fun.
Richard Newton Autocross Performance Handbook Wheel and Tire Performance Handbook |
have a lightened patrick motorsports f/w in my 3.2. It revs like a sportbike! definitely more responsive and no idle or stalling problems
996 Coupe, 84 Euro Carrera, Cayenne S, BMW CS 30, 72 2002 Ti (gone) 72 911 Hot Rod, Healey 100M, Giulia 1300 Ti, Merc 280SE4.5 Colorado Grand 03-04-05-07-08-11-17-18 Tour Auto 04-05 RG #650 |
How does the Sachs "Power Clutch" set-up Pelican sells compare to the others mentioned here?
I have to do a clutch real soon on my SC...It is a daily driver that sees a couple autocrosses a year. Thanks, Coop
Cooper's Classy Car Care Providing Clear Bra installation, Paint touch-up, Detailing PCA/OCR since 1997 '81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter |
Sachs Power Clutch is worth it. Made a very nice (more responsive) difference with my car.
same here with the sachs, highly satisfied
The Sachs Power Clutch is not having any trouble holding the 320+hp my 3.4 is making, good product.
What Randy was hinting at is that if you take too much weight out of the flywheel/clutch/PP pack then the motor looses intertia and can be hard (or different) to get moving from a start. It may also want to stall when comming down to idle. The Al PP in the Sachs kit seems to not cause any of these symptoms on its own, but one should be careful of taking too much weight out of that end of the motor. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
AutoBahned
also the DME on some cars may not "like" the signal fluctuations it gets from a flywheel that is too light - this is documented in BMW models - dunno re Porsche
Finally, the later style flywheel bolts do not need to be replaced each time - it won't hurt tho |
I have a 9lb. flywheel in my BMW 318is and it's great..especially for autox and track use. It takes a little getting use to on the street, but nothing major. Oh, there is a little more noise, well at least on my 318is anyway.
Sooo...I purchased a Patrickmotors light flywheel and the Sachs Power Clutch from our host as well as a SW chip and a TRE exhaust. However, I just got the old exhaust studs out, so all of this is still in the process. I'm expecting the same enhancement from my 3.2 that I got from my 1.8!
Woody Slow n Fast 1984 Guards Red 911 Carrera |
Apart from the increased finesse needed for starting off, a little more noise from the gearbox at idle and low engine speeds might be noted. Most of us are familiar with the rattling noise from the gearbox when the car is accelerated from too low in the rev range, in a particular gear. The engine speeds at which this occurs may change, with a lighter flywheel and clutch. JR |
Schleprock
Like the others said, I think the place to start is the clutch housing. There's much more weight in that than in the flywheel. Example: the OEM Sachs clutch housing for my 87-89 G50 is about 25 lbs. A lightweight clutch from Kennedy Engineered Products is 17 lbs. Big difference. A lightened flywheel is not going to cut 8 lbs from your existing flywheel. Not unless you start scalloping it and drilling large holes in it.
For your purposes, I think the Sachs aluminum pressure plate (Pelican catalog calls this the Power Clutch kit) is the way to go. Unfortunately they're slightly expensive these days. I remember back in 2000 you could get a complete standard 915 clutch kit for $299 and the aluminum kit was $399. Now you'll pay $525 for the std. and $650 for the sluminum!
Kevin L '86 Carrera "Larry" |
Thanks for the feedback.
![]() I will give the "Power kit" a try. The aluminum flywheel is pretty spendy though compared to a new steel one...maybe I'll wait on that part. Cheers, Cooper
AutoBahned
revived to add some data:
5.0 Flywheel, Wevo Superlite incl ring gear 5.6 Flywheel, Fidanza Al T7075 9.9 Flywheel, stock 3.2L 6.0 Patrick Motorsports steel RSR type, cutaway the ring gear itself is 0.5 lb. Naturally, wt. at the outer edge will affect rotational inertia the most. |
Scallop those b*tches...
