Best option for '67 911 heat exchanger hoses?
Hi All,
I have a '67 911 that I bought with headers installed, which I have since refitted with heat exchangers. I don't have any of the original hoses that go from the heat exchangers to the engine blower or to the rocker outlets. Remember, the '65-68 911 had those weird rocker panel heating vents.
Is there a kit available to replace all the hoses? I don't care if it looks OEM or not if it is safe and does the job.
Old 09-30-2007, 02:42 PM
Grady Clay's Avatar
You will find what you need HERE from our host.
(2) each, 616-211-295-01, this should be the high temp wire supported tubes.
(2) each, 930-211-622-01-M260, this should be the clod air low temperature tubes.
Be sure and confirm this with your Pelican sales person.
I’ll encourage you to find the original clamps from a dismantler or new OE Poesche..
Do not drive the 911 with these hoses not in place.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 09-30-2007, 05:51 PM
khamul02's Avatar
Aircraftspruce.com The hose is a lot more flexible and will probably last a lot longer.
Plus the black look fairly stock.
Here's a pic of the orange stuff:
The black:
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 09-30-2007, 08:36 PM
