Where is the Tach wire on the engine?
I have an 84 911 and the tach suddenly stopped registering at all. I am wondering if a wire is loose. Where is the tach sensor on the engine?
Rick
1984 911 coupe
Old 10-11-2007, 11:17 AM
304065's Avatar
Rick, it runs off the DME.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-11-2007, 11:44 AM
The Chef
Guest
Posts: n/a
Yup. What he said.
Old 10-11-2007, 12:10 PM
Hrm. Well bummer. I was hoping there would be a wire that might be loose.
Ok, so my tach was working fine one week and then poof! Nothing. All the other indicators on the dial work fine, even the idiot light. Any ideas where I should start? Should I pull the tach and check the back of it? I find it a little hard to think the connection would have come loose from back there...
Rick
1984 911 coupe
Old 10-11-2007, 02:51 PM
Bump...any help on where to start trouble shooting this tach?
Rick
1984 911 coupe
Old 10-11-2007, 06:22 PM
You might try an external tach (RPM meter) and tap into the back of your tach to see if you are getting any signal at all.
Old 10-11-2007, 08:17 PM
Work in Progress
Rich76_911s's Avatar
Nathan,
I'm not sure if this will help or not, but here goes:
The wires that come out of the DME that go to the tach come from slot #11 and #21. The wire out of slot #11 is a black wire, and the one that comes out of the #21 is a black/violet wire. Did any of those come loose on the back of the tach?
Isn't the tach sensor associated with the two sensors that are right off of the starter ring gear, near the clutch. I know the engine speed sensor is back there, but I am not sure if that is what send the signal to the tach or not. I think if that wasn't functioning you'd have bigger problems than a non-functioning tach though.
Do you have a Bentley Manual. I pulled mine out to try and help, but I haven't ever messed with this stuff yet. And I am just pulling at strings trying to get something together for you.
If you need something else out of the bentley manual that might help let me know and I'll try my best to find it for you.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 10-11-2007, 08:21 PM
The DME requires rotation speed of the engine; not the wheels.
Wheel speed is used for the odometer; not the engine rpm.
There's a sensor picking up the wheel rotation speed of one of the axles, close to where they connect to the transmission. The wire runs through the tunnel (under the hatch between the rear seats) forward.
Better a good one for a lot of bucks, than a bad one for little
Old 10-12-2007, 10:44 AM
