Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Porsche Bodywork Guys...best method of sanding? Tools to use?
Hi all,
I'm sanding some filler from my newly welded on flares. I know block sanding is the correct method, but there are virtually no flat surfaces where I'm sanding. What are you guys using to sand? Any special tools?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 10-07-2007, 01:03 PM
Jeff Hail's Avatar
Originally Posted by emptyo View Post
Hi all,
Use a DA (Dual action) with a soft backing pad for contours. Sounds like you skipped the cheesegrator step in roughing out the shape of the filler prior to full cure. If you need to remove a lot of filler a Jitterbug can be used also.
Jeff Hail
"All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible"
Old 10-07-2007, 01:26 PM
Warren Hall Student
Bobboloo's Avatar
I like starting with a 16" sanding file using 40 grit. Make sure you sand in different directions. I like to cross hatch across the valley. Then I move to 80 grit with the same file and finally I take 150 grit and nice round object like a role of 2" duct tape with the sand paper taped around it. I sweep the role downward across the valley.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 10-07-2007, 02:46 PM
RichF's Avatar
go to the paint store and get a 6" soft sanding pad they work wonders for the contors
"Work harder........... Millions on welfare depend on you"
" If you aint cheaten you aint tryin"
Old 10-07-2007, 04:01 PM
jmshepard's Avatar
Here is a good website for autobody help and questions:
http://www.autobody101.com/forums/
Interestingly enough I read a thread from someone asked about using a palm (jitterbug) sander. The feedback was unanimous concerning that tool…absolutely no. Anyways, that was their opinion
Jim S.
I say we take off, and nuke the site from orbit. It's the only way to be sure.
2009 Cayman
Old 10-07-2007, 04:09 PM
