replacing the internal thermostat
Whats the best method and procedure?, do I need to do a full drop or partial, also what should I replace while Im at it? thanks guys
2006 mini cooper s, w/ all johncooper options( ex wife got it)1984 alfa(Alfa heaven)1964 mini cooper s(awaiting restoration)1984 carrera (still have her)
90 dodge 4 wheel truck, 200,000 miles that 318 keeps going and going( threw a rod putting in a long block)
2006 chrysler 300 srt-8, berrian sand rail twin turbo vortec v6
Old 10-08-2007, 03:38 PM
sorry 84 carrera
Old 10-08-2007, 03:39 PM
ianc's Avatar
With a Carrera it can be done without doing a full or partial drop, but you'll be taking the AFM off and going over the top.
While you're in theres are oil press switch and breather gasket,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 10-08-2007, 06:25 PM
kqw kqw is offline
+1.....
The Fox
Carrera
Old 10-08-2007, 07:13 PM
sorry for my ignorance---ummm the afm 'air flow something or nother' maybe?. so I dont need to lower the motor but can squeeze over the top is that right? I better buy a bigger shoehorn
Old 10-08-2007, 08:33 PM
I found a good place here that describes the procedure and fixing oil leaks as well
http://books.google.com/books?id=j7wq62vJtXoC&pg=PA65&lpg=PA65&dq=replacing+internal+porsche+thermostat&source=web&ots=10UFkftz7k&sig=ugLZjzlX3z0Ox0BUPaRr-hs2UwQ#PPA28,M1
Old 10-08-2007, 10:00 PM
You need to remove the air filter box and the aluminum device (AFM) air flow meter that attaches to the rubber hose that provides air to the intake manifold. Unclip the snorkel, remove the filter and start undoing the small bolts that hold the components to the motor. Behind all that you will find the thermostat and pressure switch.
Tony G
2000 Boxster S
Old 10-09-2007, 05:47 AM
Freybird's Avatar
This job is easier if you're thin and lankey. The further you can get your head and torso wedged above the motor, the easier it will be to see what's happening back there.
+1 pressure switch and breather gasket!
'86 911 Coupe Corner bal track aligned
'09 JCW Mini Cooper '94 Suzuki Carry 4x4
'07 BMW 530xi 6spd '11 Rancilio Silvia w/PID
'79 280zx ported, rally cam(sold) '87 and '95 300Ds, (Sold)
Wisdom begins w/ calling things by their real names; A is A.
Old 10-09-2007, 07:04 AM
thanks guys well here goes------nothing
Old 10-09-2007, 11:33 AM
Update; well pulling the intake manifold was not to bad, it took me an hour. A couple of things to watch is to make sure the washers under the 12 manifold nuts are removed prior to removing the manifold or they could very easily end up in the cylinder past the intake valve if its open, and thats very bad news. Everything is obvious once its out. The breather gasket has been leaking past the flange and running down number 5 jug and making it appear it was leaking from the pushrod tube. The oil thermostat is very easy to get to also. Ill be changing the hoses I can reach and cleaning up the back of the motor, ---thanks guys for all your expert help, it was greatly appreciated, ----Rob
Old 10-12-2007, 05:20 PM
Hey Rob,
good go. BTW, and I am sure someone else will point it out so it might as well be me - 911's don't have push rods or push rod tubes. (they use overhead cams) I think you must be referring to the oil return tubes on the bottom of the engine?
Feels good to do the repair yourself and save yourself shop labor time.
Tony G
2000 Boxster S
Old 10-12-2007, 07:12 PM
ianc's Avatar
why did you pull the intake? If you just removed the air filter housing and the AFM, you could have gone right over the top of the intakes to get back there...
Oh well, good job nonetheless...
ianc
Old 10-12-2007, 08:50 PM
