Caliper Piston Scratched
I'm rebuilding my front calipers and I noticed that one of the pistons has a parallel scratch that runs the full length of the piston. Its very light, like someone took very sharp razor blade and put just enough force to leave a scratch, but it can be felt with the fingernail (but only barely).
I've scotch brited the piston but the scratch was still there. Then I polished the piston with my dremel to see if that would get it out - nope. However, I'm not sure I should have polished the piston b/c when I put brake fluid on the metal it didn't coat in an even sheen like the previous pistons, it beaded up like on a well waxed car. I'm not sure if its like a piston in the engine where it needs to be honed.
So some questions:
1. Will this scratch cause a leak or air to get into the system. Has anybody ever rebuilt pistons with very light scratches and came away OK.
2. do I need to remove the piston and use some 2000 grit sandpaper and wet sand a hone to it?
3. I'm I screwed and need to buy new pistons (if they even sell them) or rebuilt calipers?
1986 944 Turbo - Guards Red
Old 10-10-2007, 05:25 AM
I wouldn't worry too much about it about it. The piston just pushes the little rubber seal that seals with the surface of the cylinder. The only downside might be that the groove might pick up some dirt which could theoretically scratch the cylinder surface. Practically no worries. IMHO
Diverdan
Old 10-10-2007, 06:26 AM
aj88cab's Avatar
Actually the piston moves against the seal which sits (stationary) in a groove in the cylinder. A scratched piston will eventually damage the seal. Replace the piston.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 10-10-2007, 06:36 AM
moneymanager's Avatar
What a range of opinions. If the scratch is parallel to the piston's travel, as you suggest, you have very little to worry about. The worst thing that can happen here imho is that you might have to rebuild the caliper again in a few thousand miles.
Old 10-10-2007, 07:42 AM
IMHO - buff (not in the parallel to travel direction) with 800 and give it a try with a new seal - probably be very ok - in the mean time maybe order another piston and put in the tool box incase there is an issue downstream. Put a few drops of bf or one of the brake piston lubes on the piston and seal before asm. May want to buff out the cylinder and see if you run into the debris. It is hard to get in there, I use a very fine scotch bright type material and then flush/clean. As others have mentioned in other posts... don't split the body of the caliper.
Old 10-10-2007, 07:53 AM
If I use sand paper, I assume I would wetsand the piston in a crosshatch pattern. Is 800 high enough grit?
My concern it that this very fine sratch would let brake fluid out or air in.
Old 10-10-2007, 08:51 AM
Slumlord
Porsche_monkey's Avatar
What does a new piston cost, about $50 (for two)? Why bugger around and waste your time?
Just replace it, it's not worth the agravation if it leaks.
Old 10-10-2007, 08:57 AM
if you want to use 1000 grit, that should work as well or even higher.
re. cross hatch - I tried to keep the pattern about 90 from the direction the fluid wants to try and get out. I think the way it works is that the piston slides on the rubber seal... when it starts to fetch up the seal grabs the piston, as the hydraulic pressure rises, and flexes for the final movement to apply hard braking. You may be too worried about this...
Old 10-10-2007, 09:00 AM
I only found some SS ones on pelican (a set of 4) for over $200.
Can you point me in the right direction for buying them individually?
Old 10-10-2007, 09:53 AM
Somatic Negative Optimist
Gunter's Avatar
Have a feel inside the caliper to see what caused the scratch.
If it didn't leak before, do a fine polish and re-assemble.
The square seals are very forgiving.
Expect to bleed the system a few times all around before the pedal feels hard.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-10-2007, 09:54 AM
BertBeagle's Avatar
Rule of thumb (nail) if you can feel a scratch then replace the piston. If this is an aluminum caliper do not go honing or sanding the caliper bores. If it is an aluminum piston you will damage it by sanding on it.
Without seeing the piston and caliper that is about it.
The seal is in a groove in the caliper piston bore. The piston moves in the bore (and seal) when the brake is applied. If there is a scratch deep enough to feel or through the anodize (on aluminum pistons) then it should be replaced.
If you are still not sure take the piston and caliper to a trusted mechanic.
Old 10-10-2007, 06:27 PM
good points I assumed steel piston and caliper.. that's what I have...
redcoupe... can you post a close up of the scratch? maybe we can get some idea of the depth...
Old 10-10-2007, 06:32 PM
BertBeagle's Avatar
If the caliper is cast iron and the piston stainless or plated steel - the same rules apply although you can polish a stainless piston with scotch brite. However if it has a scratch deep enough to feel it needs replacing. Yes you can sand a steel piston to remove a light scratch but then you do not have a round piston. It may seal but I would not put it in my car or a customers caliper.
Old 10-10-2007, 06:43 PM
Early_S_Man's Avatar
Porsche Crest
The OEM pistons are hard chrome plated, and from your comment [and obvious concern] about brake fluid not 'wetting' the piston surface along the scratch ... it sounds like the plating may have come off during your buffing operation. It probably won't give you any leaking problem near-term, but how long are you willing to drive the car with 'worries' in the background whenever you step on the brake pedal???
The piston was probably scratched during disassembly for a previous rebuild by a grain of sand imbedded at the chamfer of the caliper bore. Compressed air can move that piston rather rapidly!
This problem illustrates why silicone grease should always be used during caliper rebuilds! It does not run or migrate once installed. A 'bead' of silicone grease at the bore chamfer/piston interface acts as a barrier against entry of dirt or sand, even if the rubber dust shield is cracked or torn away!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-10-2007, 08:23 PM
BertBeagle's Avatar
This is good advise. Use only silicone grease designed for brake system rubber seals - that is a silicone grease that does not cause the rubber to swell. Brake rubber seals are made of EPDM or EP rubber.
Old 10-11-2007, 04:25 AM
Slumlord
I must have mis-read the web-page, because I can't find it now
Buy a used caliper.
Old 10-11-2007, 04:33 AM
Where do you all suggest buying a used caliper from. Does PP have them. I only see new.
Buy a used caliper.
Old 10-11-2007, 05:29 AM
along these lines.... has anyone made a tool to reach in.. expand and "grab" the piston to turn slightly to line them up or work back and forth to get the piston out without using fluid/air compression? I guess this winter I'll take out my pistons and see how the buffed off or buffed chrome is doing... it sure didn't look like there was a plating on there last time I had them out.
Old 10-11-2007, 05:42 AM
re. used caliper... an idea(s) put out a WTB on Pelican used parts forum and maybe call Parts Heaven Hayward CA. I think they are in Hayward. Google it and it should pop up.
Old 10-11-2007, 05:44 AM
Slumlord
Try the 'Used Parts Classifieds'.... post a 'Wanted to Buy'.
