Porsche Crest Tie Rod End Question
I'm in the process of completing a brake upgrade on my '81 SC including caliper rebuild & paint & rotor/pad replacement. Found one of my turbo tie rod ends shot. I was able get it disconnected from the arm, but I can't seem to get enough leverage with a wrench to hold the rod still to unscrew the end.
Does anyone have any suggestions to loosen the end? Any tools that would help?
Old 10-11-2007, 10:15 AM
midnight911's Avatar
there's a recess on the rod where 12mm open wrench snugs... if it is seized, grab the tie rod end side with a channel lock and twist. apply heat if stubborn...
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 10-11-2007, 11:28 AM
Thanks, I'll give it a try.
Old 10-11-2007, 04:25 PM
