I am removing aftermarket exhaust and installing 1983 oem he's and exhaust.Problem is he,s hit an oil line that goes across front of motor under bell housing and leaves me no room for cross over pipe.I am not sure what i need to do,do i need to change the oil line?what part do I need and/or where does the line go?thanks for any help.
The oem exhaust is paired w/ an oil line that goes to the back of the engine and crosses from drivers to passengers side behind the muffler
part # you will need is 911.107.741.11 here I believe that you need another oil line as well, call Pelican and explain what you are doing.
I have a bead blasted perfect #20 in that parts diagram, yours for the cost of shipping.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
I have both oem take off oillines from my stock 79 Sc , I will swap for the lines you have .
pending pics. email hbkramer@aol.com
HB Kramer (4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete) (2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well. |
oil line info
thank you for the help!Great info,now I know where to look.will give it a try and let you know.mark
