Loss of power then backfire
Last weekend I attended a DE at CMP. While on the track, I was driving and the car just shutdown. I looked at the tach expecting that I had forgotten to up shift and hit the rev limiter (did I mention this was during my very first solo run) but, it was only at about 5k. In just a second or so it backfired and everything was back to normal. I came in and looked at the obvious, coil wire, battery shifting, etc. nothing was out of the norm. I returned to the track for the remaining 15 minutes and also one more 30 minute session after that then a 3 hour drive home. No more issues.
This is a stock ignition and CIS car. Any suggestions of things to look for?
Seems fine now but certainly don't want to have something simple leave me stranded.
Kevin
'79 Coupe
Old 10-12-2007, 10:24 AM
Kevin:
A few things,....
How many miles are on your car?
How much gas did you have in the tank?
Some ideas:
1) I would be carefully inspecting the green trigger wire from the distributor as those can be troublesome and create the symptoms you describe.
2) I would also carefully inspect the fuel pump connector, wiring, fuse, and associated components.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-12-2007, 11:19 AM
Steve, thanks for the reply. The car has just over 190,000 miles on it. I rebuilt the engine at about 172k which was 2.5 years ago and have had no issues since.
There was plenty of fuel.
I have thought often about that green wire. I do know the insulation is very rigid and looks like a part that could fail. Honestly even though I have looked and thought about it I have never considered replacing/repairing it.
The fuel wiring and pump are likely original. Would the backfire indicate fuel was still being pumped in while there was no power or not necessarily? It was a very loud, one shot backfire.
I will check these and any other possibilities this weekend.
Thanks again for your time,
Kevin
Kevin
'79 Coupe
Old 10-12-2007, 12:07 PM
Early_S_Man's Avatar
Porsche Crest
For some really good, comprehensive pics of the green coax cable before and after pics ... go to this thread:
Green "dizzy" wire replacement help@
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-12-2007, 03:33 PM
