Loss of power then backfire
Last weekend I attended a DE at CMP. While on the track, I was driving and the car just shutdown. I looked at the tach expecting that I had forgotten to up shift and hit the rev limiter (did I mention this was during my very first solo run) but, it was only at about 5k. In just a second or so it backfired and everything was back to normal. I came in and looked at the obvious, coil wire, battery shifting, etc. nothing was out of the norm. I returned to the track for the remaining 15 minutes and also one more 30 minute session after that then a 3 hour drive home. No more issues.
This is a stock ignition and CIS car. Any suggestions of things to look for? Seems fine now but certainly don't want to have something simple leave me stranded.
Kevin '79 Coupe |
Kevin:
A few things,.... How many miles are on your car? How much gas did you have in the tank? Some ideas: 1) I would be carefully inspecting the green trigger wire from the distributor as those can be troublesome and create the symptoms you describe. 2) I would also carefully inspect the fuel pump connector, wiring, fuse, and associated components.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Steve, thanks for the reply. The car has just over 190,000 miles on it. I rebuilt the engine at about 172k which was 2.5 years ago and have had no issues since.
There was plenty of fuel. I have thought often about that green wire. I do know the insulation is very rigid and looks like a part that could fail. Honestly even though I have looked and thought about it I have never considered replacing/repairing it. The fuel wiring and pump are likely original. Would the backfire indicate fuel was still being pumped in while there was no power or not necessarily? It was a very loud, one shot backfire. I will check these and any other possibilities this weekend. Thanks again for your time, Kevin
Kevin '79 Coupe |
For some really good, comprehensive pics of the green coax cable before and after pics ... go to this thread:
Green "dizzy" wire replacement help@
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
