Wickd89's Avatar
What typically goes out: DME or DME Relay (is there a diff)
I am taking a road trip and ordered a DME relay (noted as the item that goes under the seat). It is a little 6 prong black box.
Is this the correct spare part to carry around?
Thanks,
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 11-06-2007, 11:15 AM
the the is offline
That's the correct spare.
The DME "brain" can fail, too, usually when a soldered joint cracks. But that's relatively rare, and it isn't really economically feasible or necessary to carry around a spare DME brain.
Old 11-06-2007, 11:18 AM
My thoughts exactly.
Old 11-06-2007, 12:55 PM
York's Avatar
You might want to install the new relay and keep the old one in your glove box as an emergency spare, that is what I did on my '86. The old one was working, but it had cracks in several solder joints.
'86 911 Sunroof Coupe
'91 Miata
'77 BMW R75/7
Old 11-06-2007, 01:02 PM
Wickd89's Avatar
Thanks!
I was just a little surprised how small the unit was when I got it. I thought the unit had a different shape.
Old 11-06-2007, 07:32 PM
3.2 CAB's Avatar
It pretty much looks like any other relay. I have seen some other dual function relays, and they all look pretty much the same as any standard relay. I guess this is so they can fit in relay panels along side of the others. That was a good idea to go ahead and put the new relay in, and get a new spare for the trip. Keep the old one in the tool chest for future use, testing, etc. Good luck on the trip!
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 11-07-2007, 07:14 AM
Wickd89's Avatar
Planning a trip up the coast
Laguna Beach to Santa Monica to Santa Barbara to San Luis Obispo to Carmel to Santa Cruz. Driving highway 1 along the coast and will take tons of pics. Will also be playing Spanish Bay so loving life right now, knock on wood!
Old 11-07-2007, 07:34 PM
slodave's Avatar
Luis, next to the DME relay, is the DME (brain), usually a silver box. It can be prone to solder failure as well, but the relay usually fails first.
Dave
Old 11-07-2007, 10:23 PM
Wickd89's Avatar
Thanks Dave.
are you back from Europe??
Old 11-07-2007, 10:27 PM
slodave's Avatar
Originally Posted by Wickd89 View Post
Thanks Dave.
You are welcome.
Yes I am and drinking a Bitburger .
Dave
Old 11-07-2007, 10:30 PM
Early_S_Man's Avatar
Porsche Crest
Luis,
You can resolder the printed circuit board illustrated in the pic below ... ideally, all of the finished joints should look like the one in the lower right corner with an 'Iron Cross' pattern reflection off the solder. When finished you should have a good spare.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-08-2007, 10:23 AM
I love the central coast. You'll be driving right by our house in Morro Strand (Morro Bay). Lots of great places to see and places to eat/ stay.
When I go on a road trip I usually carry the usual tool kit, flares, tire pump, jumper cables, and extra tools such as a soft socket, 1/2" ratchet, socket to remove the fan belt nut, extra fan belt, allen key set, and a large adjustable pliers to remove the dust cap for the front wheels. I also carry an electrical crimper and extra wire and solderless connectors.
No, I do not travel lightly but when you're stuck on the side of the freeway you want speed in getting back away safely. And I've had occasion to use pretty much all of these tools during various emergencies.
Old 11-08-2007, 04:02 PM
