Designer King
Vacuum Advance or Retard?
My engine is a mongrel, including using an S dizzy. There is only 1 port off the vacuum unit and it is located on the top. Is this an advance or retard?
In either case, is it necessary? I do not have to worry about emissions testing, I would just like to get the best running condition.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Put vacuum on it and see.
Designer King
Bill,
I don't have a vacuum pump. Will ordinary lung power be sufficient? If it is a retard, will I hear the revs decrease, or if advance, increase? Or do I need to hook up a timing light? I read an old post by (I think) Early S Man, who said these were retard units. If so, apparently I can disconnect it for a better idle. Can it remain open or should the port be plugged?
Lung power will do it.
At idle, retard will generally slow the engine, advance will speed it up.
