ianc's Avatar
Angry Double whammy...
I took off the wheels tonite to grease the ER polybronzes and got to the RR last, but there were a couple of nice surprises waiting for me there:
Looks like I'm doing boots. Although, there's something different about the 85(?) and on that makes this more difficult? Can't recall; will have to look it up.
Worse, shortly thereafter I noticed that my RR sway bar bushing is essentially hanging. The welding on the bracket is globular at best, so it appears to have been done before.:
Not smiles all around. Ripped of course, although I’m not sure why. I don’t track the car or really drive hard enough to rip a sway bar mount loose. My only guess is that the bushing bound to the bar or wouldn’t allow it to turn and it ripped out the mount instead.
I would like to do CV boots and repack, then have replacement sway brackets welded in, along with a couple new sway bushings.
Or, does anyone think I should weld up the torn existing mount, and ensure easy bushing movement, then call it quits? The car has 22's & 29's and stock sways (to my knowledge). Rear is ~ 22.5 mm.
It's the suck, but it gets things fixed I guess. Is it only talc that's recommended for lubing these? Who makes the best brackets? Thanks for any thoughts, or any tips I don't know (particularly on the bracket),
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 09-24-2007, 10:30 PM
Get Wevo --Its the only way!!!http://www.smartracingproducts.com/pdfdocs/533015_wevo_arb_rearmount_pics.pdf
Old 09-24-2007, 10:36 PM
Warren Hall Student
Bobboloo's Avatar
The factory sway-bar mount rips because that's just what they do. They really were under designed.
As Bob says get the Wevo and this will be the last time it will have to be repaired. Pelican sells them as well.
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911M&section=SUSshk&page=7&bookmark=14&part_number=WVO-RARB
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 09-24-2007, 11:48 PM
burgermeister's Avatar
No way the rubber constrained the sway bar from rotating enough to rip the metal mount, unless it was already pretty cracked.
A 1.2mm (I'm exaggerating a wee) folded part holding a 22mm sway bar on the vehicle is just plain silly. Fix it & box it (loosing access to the weld nuts - could get annoying in the future) or use the above suggested part.
Do those Wevo parts weld on? They look thick to weld to body sheetmetal...
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-25-2007, 01:54 AM
Heres the full guts--Tyson post---http://forums.pelicanparts.com/showthread.php?t=221342&highlight=wevo
Old 09-25-2007, 02:45 AM
I ripped two off on my 87 coupe. Porsche has a replacement [probably aftermarket also] that welds right in.
63 356 2.1 Rally Coupe
75 911M 2.7 MFI
86 Sports Purpose Carrera "O4"
19 991.2 S
Old 09-25-2007, 03:09 AM
ianc's Avatar
OK, looks like I'll be ordering up a set of the WEVO's.
How about the bushings? Anything better than the factory rubber available, or is that OK?
Also, what products would you use to prep the area around the weld after it's been completed? Just prime and paint from a rattle can? POR 15 or something? Dunno; I've been blissfully free of any rust-related issues here in CA thus far...
Thanks for the advice...
ianc
Old 09-25-2007, 08:11 AM
MBruns for President
JeremyD's Avatar
Swaybar mounts suck - get the WEVO
Old 09-25-2007, 08:40 AM
JTL JTL is offline
JTL's Avatar
Arrow
I've been lucky so far with the rear bar mounts but the wevo mounts are on the list though. It's probably safer to take care of those before the inevitable happens.
Repacking the cv's isn't too bad, just very messy. Get some of those thin blue rubber gloves and a buncha rags etc. and guess you need new boots. I repacked mine 2 years ago and put in new bolts and washers. The bearings did have some wear but not bad so they went back in.
jt
-84 targa
Old 09-25-2007, 08:49 AM
RETIRED
Joe Bob's Avatar
If that's a 915 trans....I have a set of rebuilt axles available.....
2012 ML350 3.0 Turbo Diesel
Old 09-25-2007, 11:14 AM
ianc's Avatar
Hi Mike,
Nope, it's a G50 I'm afraid.
Could still use some advice on products to use for prepping the weld area though if anybody's got some helpful hints...
ianc
Old 09-25-2007, 01:04 PM
ianc's Avatar
Well,
I took care of this nasty little business over the weekend at my friend's shop. Luckily the place next door to my friend's shop is a metal fabrication business, so I had one of the guys come over and weld the WEVO pieces on after I'd finished grinding the old ones off. Not an exceptionally neat welding job, but looks solid. Finished up with a couple of coats of POR15.
All in all a nasty PITA...
ianc
Old 10-15-2007, 01:01 PM
450knotOffice's Avatar
Looks good. I really should just do this (have it done) before mine rip out by themselves.
Old 10-15-2007, 01:05 PM
