O2 sensor protection plate
What is the proper direction to face the O2 senor protection plate?
TIA Jeff
87 Carrera Cab GP White 01 740i Sport 03 Honda Odyssey |
The shield portion (( should face the catalytic converter
cat (( sensor |
THE IRONMAN
It's a heat shield....position it to protect the sensor from heat...
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
The O2 sensor screws into the CAT. The plate cannot protect it from heat. I doubt that there is a hotter place on this car. I think the protection plate is to guard the O2 sensor from rocks kicked up in the wheel well and that it should face the tire but I'm not sure.
In my car, which I believe to be original, the shield is snapped onto the O2 sensor and faces outwards towards the tire, not the engine. I think it is there for protection against road debris.
Chuck '96 993 C2 coupe '87 Carrera coupe - gone but not forgotten many lesser vehicles |
Indeed, debris protector...towards the wheel.
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
yep,..debris protection (not heat).
Best,
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
yes..debris protector... exactly what angle it should be is a good question...I usually put it "facing" a bit toward forward... assuming rocks would come from that direction..
don't loose it... they are hella expensive for what you get.. ops.. can I say hella on this forum...? sorry, been listening to my kids too much about 5 years ago. |
