Eye of the Toiger
matty74's Avatar
Strange Tapping sound when engine is HOT
I recently had my 3.0 SC motor rebuilt top and bottom, heads and CIS overhauled. I installed a 3.2 oil pump and oil redirection.
I drove it nice and easy during run in and and it runs beautifully and pulls hard.
Now when I sit in traffic and it gets above 180 C it starts to produce a noticable tapping sound at idle and not in gear. I have removed the fanbelt it's not the alt bearing and it sounds like its comming from the lower pully although I can't be sure.
It only does it when it gets really hot, when under power it does not make the sound.
I have all the rod bolts and and internals machined new big and smallend bearings pots redone and new rings etc.. The tapets and cams were re-used.
new chains and rails, re-used oil fed chain tensioners.
Is the 78SC just a noisy motor or is there somthing that was missied.
Matt
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 10-24-2007, 06:01 PM
BURN-BROS's Avatar
Common noise on the SC, raise your idle a bit.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 10-24-2007, 06:21 PM
Eye of the Toiger
matty74's Avatar
It already idles at 1100 rpm I think the CIS is running a bit rich
Old 10-24-2007, 08:31 PM
BURN-BROS's Avatar
Then reduce the idle. It is most likely intermediate gear backlash that presents a condition at a certain rpm.
Burnham Performance
Old 10-24-2007, 08:49 PM
