Strang noises ...
![]() After taking a drive today, I noticed that the car was making a strange slightly clanging noise. I thought it was from the muffler or exaust, but after opening the engine compartment, I noticed that it seemed to be coming from the large fan. It can only be described as a tinny, clangey metallic sound. And I only hear it a low revs or idling at a light. Any help is greatly appreciated. Thank you…..in advance.
1964 Blue 356SC Coupe (Disintegrated from rust) 1970 Orange 911T Targa 1977 Black 930 Turbo 3.0 -1988 Carrera slant nose (Sold) 1996 Black 993 Cab.(Sold, and back in Germany) 2006 Slate Grey Carrera S coupe |
Does there appear to be any scrapes on the inside of the fan shroud?
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
I haven't seen any. are you thinking burrs of metal hitting the shroud?
Not really, just wondering if something shifted and maybe was rubbing. I hope you find the problem!
Dave
I'm not sure how the pulley is keyed on the alternator shaft of the newer engines, but my 3.0 liter made the same exact sound you are describing and it turned out to be the pulley keyway was worn and causing radial play which made a bell ringing sound. Hope this helps.
78 911 SC "Scratchy" 2004 Mini Cooper S "Pele" (gone but not forgotten) 1979 classic mini clubman-"Coolio" |
Transplanted User
It's a little half-round metal pad that inserts into a slot in the drive shaft, and that keeps the shaft and fan spinning together. You will need to remove the fan to access the keyway (you can remove the belt and wiggle the fan to check for excessive radial play before you completely remove it). I'd agree that a worn one is likely your issue.
Matty K. - 82 SC Targa - SCWDP member #0052 "Racing - the sport that requires more than one ball to participate" |
Transplanted User
Not a major job at all! It's really quite straightforward, if you have the correct tools. If you don't already have one (or something better), I'd recommend that you get a Bentley Service Manual. You need to make sure that you understand the preparation and tools required, and the steps to dis- and re- assemble.
Sorry if this last bit of advice seems like a little overdone Captain Obvious impersonation, but I have seen too many nice people just kind of plunge into work on these cars and and up very frustrated. Good luck!
I'm having trouble visualizing this. Is it the actual fan and the shaft that it rotates on? Personally, I don't think I could do it myself.
