slodave's Avatar
Pissed off at Targa top. Any suggestions?
Hi!
I have followed all of the Targa top threads and know about the aftermarket seals that don't fit. One major problem is just that. I tried a friends completely unmolested top and it fit without a problem.
Anyway, the pics below show my other problems. This roof was recovered over ten years ago and since, has never fit right. One problem, is that the two center panels were mounted a little bit proud and this causes about 12" of the center to ride on the windshield frame. This has exaggerated the wear of the front frame, where the inner clips go. Now it is at the point where the right center clip pops when you just breath on it.
Any Macgyver ideas out there on how to fix (temporarily), until I can once again afford to through $$$ at it?
I was thinking of using some JB weld to fill in the worn areas. I was also thinking that I may be able to carefully remove the inner liner and maybe readjust the inner panels. I know that it would be easier to send this out to fix, but.....
Dave
Bobboloo suggested that I take the frame to a aluminum/magnesium specialist and have the areas weld-filled back in.
Old 10-20-2007, 06:12 PM
slodave's Avatar
Bugger, this was supposed to be in 911 tech forum. My bad!
Old 10-20-2007, 06:26 PM
Driver
Noah930's Avatar
Why not just weld in a coupe top, instead? Less fuss in the long run.
1990 Black 964 C2 Targa
Old 10-20-2007, 08:34 PM
slodave's Avatar
That would be too easy!
Old 10-20-2007, 08:39 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
ONE WORD......Convertible !!
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 10-20-2007, 11:23 PM
slodave's Avatar
Um, no!
Old 10-20-2007, 11:33 PM
I'm sure it was meant to be a joke, but could you actually weld in a coupe top onto a targa? Does the body have the correct support in it?
I know it's a wierd question, but I am currently trying to sell my targa (which is an absolute peach of a car mechanically) to buy a coupe to re-do. I wonder if it would be cheaper if you could source out a coupe top and have someone weld it in there...
Is it even possible?
Rick
1984 911 coupe
Old 10-21-2007, 09:07 AM
slodave's Avatar
Thom - Widebody911 makes a fiberglass (carbon fiber) shell for convertibles. If you can attach a repro, I'm sure that you could put on a metal coupe shell.
Now, where is a mod to put this in the tech forum??
Old 10-21-2007, 11:26 AM
slodave's Avatar
This is how it came out after the first coat of JB weld. Tonight, I'll fill it in some more. If it all cracks, then I'll see about trying to find someone fill it in for me.
Old 10-21-2007, 12:51 PM
Canadian Member
911Rob's Avatar
Easy; my targa........
Rob McKibbon
Arena Red 96 993 TT LINK
Contemplate YOUR Success!
Old 10-21-2007, 01:31 PM
efhughes3's Avatar
Ummm, don't use the top? Encino Man would infer you live in the land of no rain...
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-21-2007, 01:46 PM
slodave's Avatar
It's getting that way. I use the top to keep the Targa stiffer when we drive the canyons. It really helps.
Dave
Old 10-21-2007, 05:11 PM
Senior Member
Dave,
Mix the JB Weld with some scrapings off of the shop floor from around the drill press. Residue from drilling holes in metal works very good and hardens up the JB to the point where you can do almost anything with it.
Old 10-21-2007, 06:39 PM
Grady Clay's Avatar
Some high end post for you.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 10-21-2007, 06:54 PM
slodave's Avatar
Originally Posted by Joeaksa View Post
Dave,
Good idea Joe. We'll see how the JB weld holds up as is. If it fails, maybe I'll get some shavings and give it another try. I had the roof on this evening and it hasn't popped yet. Thanks for the idea!!
Dave
Old 10-21-2007, 07:37 PM
slodave's Avatar
Alright, I don't have easy access to metal shavings at the moment, so I took a beer cap and some sand paper and viola - instant metal shavings. I took a magnet to the JB weld that I mixed last night and it is magnetic, so there is metal in it, but not much. The new batch with added shavings is really magnetic.
Before the JB weld hardened last night I used an X-acto and scored it a bit. I hope this helps the second layer bind.
Old 10-21-2007, 08:16 PM
Autobahn Garage
If you can take the cover off and send just the frame to me I'll weld it up for you (no charge) jusy pay the shipping both ways. Let me know if I can help
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 10-21-2007, 08:29 PM
